I hate Sbc Starters!!
Discussion in 'The Hokey Ass Message Board' started by Shaggy, Apr 2, 2008.
  1. Shaggy
    Shaggy
    from Sultan, WA
    So the first 3 new starters i tried on my 64 camino were too long, hit the crosssmember, I finally get one that fits and go to crank it over and Zing, nothing, sooo, that means i have an issue with the wrong starter to flywheel, i'm running a 153 tooth and aparently the starter is for a 168?? Right?? Is there anything i'm missing??
  2. jonny o
    jonny o
    If it's new, and the flywheel is in decent shape... sounds like it's time to start counting. If the teeth are right, it might just need shimmed.
    If you can find a local automotive electric shop, and have no other option, I ran a beefed up v6 starter for a while. Not too much compression and wrapped it in heat blanket.
  3. Starter shims? Those have always been my achilles heel.
    What motor/trans combo are you running?
  4. 53sled
    53sled
    from KCMO
    Sounds like you need an 86-up starter, What is your combo?
  5. Deuce Roadster
    Deuce Roadster
    153 tooth flywheels require the straight across pattern starter and the 168 tooth flywheel requires the staggered pattern starter.
    Staggered above ( 168 T )
    Straight across pattern above. ( 153 T )
  6. Psychobilly351w
    Psychobilly351w
    from 732- NJ
    I hate sbc.... sorry I cant offer you any advice tho..
  7. Mr48chev
    There was a thread on here discussing Chev flywheels and starters a few days ago.
    Did you by chance swap a V8 into a six cylinder car?
    It almost sounds like the engine is sitting too far forward if you are having problems with the cross member interfering with the starter.
    Did you swap engines? and if so what engine/trans combination do you have?
    Count the teeth on the ring gear. That will take marking one tooth and rotating the flywheel By hand while you count the teeth. Then make sure you have the correct starter according to what Deuce Roadster posted.
  8. 54BOMB
    54BOMB
    Did the gear ring fall off the flywheel , I had that happen to me once.
  9. 52 csb
    52 csb
    Dont hate the eng hate the engineer. Flywhee/ starter drive must have .035-.040 in clearance. Shimming bolts increases clearance. Shim outer bolt and you decrease clearance. Ps, that was a great thread adv.
  10. Shaggy
    Shaggy
    from Sultan, WA
    M-20, Lakewood bell, mid 70's 350, and new 153 tooth flywheel,
    and deuce that is what i thought too, but i've heard people say elsewise lately, it is an iron cap staggered though so that's probably my problem
  11. restin&rustin
    restin&rustin
    from illinois
    try the straight across bolt pattern starter,and summit, speedway,or basicly any supplier that deals with any racing or performance parts offers a mini high torque starter that looks good and functions well.
  12. Deuce Roadster
    Deuce Roadster
    Put a straight across pattern on it ...
    I like the GM factory 88 Corvette type myself.
    I run them on my 32's with the 430 HP SBC's ... This is NOT my auction ... just a example of the starter :D
    http://cgi.ebay.com/ebaymotors/NEW-...ryZ33576QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  13. They actually made starter noses that were both pattern. I have a few of them, they come in handy when donig these odball swaps. Everytime I go to the bone yard I am always looking for them.
  14. 325w
    325w
    One of the most over looked easy fixes is new bolts. We all should replace the bolts if we replace the starter. I just put a mini on my 5w. It worked great the first try. New bolts come with it. I'm using a Delco Delphi from over yonder. I just happen to have several in stock with new bolts for $90. + ship. Oooops that may not be legal. I don't know how to post the pic.
  15. ray
    ray
    from colorado
    the starter for a 4.3 v6 has a shorter motor housing and bolts right up. i've used them on high compression smallblocks with clearance problems.
  16. FritzJr
    FritzJr
    You can swap the noses on most Delco starters. Use the nose that fits your flywheel. There are always junk starters around that will donate a nose.
  17. i love them , they have been very good to me
  18. restin&rustin
    restin&rustin
    from illinois
    ive never swapped heads on them does it affect the throw of the bendix?
  19. David Chandler
    David Chandler
    When I put a 305 in place of a 250 in my Nova, I used the 6's flexplate and starter. The block was drilled for the straight across pattern, like the 6 was.
  20. Shaggy
    Shaggy
    from Sultan, WA
    Nah my daily eats noses it doesn't care how many shims i put in or dont, missing a couple teeth and it is a little too advanced
  21. Not2low
    Not2low
    from Eaton,Ohio
    You need part number 3663.It has the short housing and straight across bolt pattern.I would keep some shims near because you will probably need them.
  22. get a high torque mini starter, I bust 3 stock ones till I got pissed off and finally spent the cash and got one...much easier to set up and a lot smaller...
  23. Johnny1290
    Johnny1290
    I was in starter/flywheel hell about a month ago. Finally I wised up and bought a mini starter from DB electrical on ebay. I liked the idea it was all new vs the rebuilt autozone junk. I think it cost 85 shipped. It was way smaller and indexable for cleareance. It fits either a 153 or 165 tooth flywheel. So far so good.
