I have an Air bag set up question
Discussion in 'The Hokey Ass Message Board' started by GEORGIADAWG, Aug 30, 2009.
  1. GEORGIADAWG
    GEORGIADAWG
    If i only wanted to put the front end of the truck on the ground when parked would it still cost me the same as an entire set up or is it cheaper? Is there any reason this cant be done?
  2. Novaracer
    Novaracer
    It would be quite a bit cheaper but you will still need a compressor,air tank,2 bags and valves.you could run 2 valves but I would reccomend 4.The truck will ride better with 1 up and one down valve per wheel.To also do the back you would need 4 more valves,2 bags,some type of 4 link system and a frame notch.Check out www.suicidedoors.com they sell and can make everything you need.
  3. The Law
    The Law
    from N. AZ
    4 valves is nice. Shared air can be dangerous. You can also isolate the sides with 3 solenoids and check valves.
  4. Salty
    Salty
    from Florida
    Cheaper? yes....but not as much as you think, the main cost resides in the compressors and valves...if you went with slam specialties bags (only reason I use this is cause I know for a fact what they cost cause I just bought 4 of em) it'll save you $150 and another $100 for valves, and bout $50 for mounts (high end) $300 savings....personally I'd just go the whole way....why half ass it (literally)
    Once you do the front I'd put money on the fact that you'll do the back....
    I think someone round here already pointed you towards Kustombuilder here....
    He can save you that coin and still get the full system.
  5. zman
    zman
    from Garner, NC
    Check with kustombuilder here on the HAMB, he can get you a complete rig fro less than you probably think.
  6. GEORGIADAWG
    GEORGIADAWG
    thank you guys for the info on kustombuilder. I will keep that info for when im ready to get the system.
  7. El Caballo
    El Caballo
    from Houston TX
    You should just put it on one side... :D
