Hot Rods I Just Bought 3 Early Hemis. I’d Like Your Knowledge/Input.
Discussion in 'The Hokey Ass Message Board' started by TorqueMonster1, Nov 4, 2025.
  1. TorqueMonster1
    TorqueMonster1
    Thank ALL of you for looking at my post. I just bought 3 Early Hemis. I sure could use some help in figuring out EXACTLY what I have. ALSO, I would like to hear from you all about what you think would be a good/fair price for me to have paid for them, it was a package deal. If you don’t want to say publicly what you think the price should be that I paid then please send me a private message (if that’s possible on this forum).
    First picture is of a Desoto. I was told it was a 330, as I recall.
    2nd picture is of a Imperial 392, no transmission.
    3rd picture is of a 354 with a 727 automatic transmission, (as I was told, I don’t know for sure). The seller didn’t say what it was out of originally, more than likely because he either didn’t know or didn’t remember.
  2. squirrel
    neat!
    So you didn't look at the numbers stamped on the top front of the blocks?
    did you know the 727 was introduced a few years after the Hemi was discontinued, and has an aluminum case, which has the bellhousing included as one piece (not bolted on separately)
  3. silent rick
    silent rick
    need more information, did you run the numbers stamped in front of the valley cover to verify that they are what you say they are? Do they turn over? Did you get them from a friend, do you know any history on them? Also depends on where you are located, prices will vary around the country.
    All I see are cores
    bchctybob and Tow Truck Tom like this.
  4. All 3 look to have been exposed to the weather for quite a while. Never a good sign. Did you pull dipsticks?
  5. 57Fury440
    57Fury440
    Unless it has some sort of adapter, the old Hemis would have a cast iron transmission.
    bchctybob likes this.
  6. 331-354 driver side top water pump bolt is very close to deck of block . 392 driver side top water pump bolt are about 1/2 inch from deck of block..........early 331 had internal bell housing......331 heads do not have water outlets on heads........354 heads have water ports dodge red ram does not have side motor mounts as stated numbers are on top of block in front of valley cover go to hotheads.com for number id.... hope this helps
  7. Cliff Ramsdell
    Cliff Ramsdell
  8. Ziggster
    Ziggster
    In my area (South Eastern/Western Ontario, Canada), prices range from around CAN$1,500 for non-running/incomplete to around CAN$3,000 for ones that supposedly ran at one point.
  9. RodStRace
    RodStRace
  10. JD Miller
    JD Miller
    They are heavy :D
    tractorguy likes this.
  11. bchctybob
    bchctybob
    If you paid less than $3000 for everything, you probably did ok ***uming that they are rebuildable.
    If you remove the transmission from that one, save the starter plate that’s sandwiched between the block and the bellhousing. They are often needed when adapting a different transmission to the old hemis.
  12. SS327
    SS327
    You got screwed, I’ll give you $500.00 for s**** and then come and pick them up at my earliest convenience.
    MAW, j hansen and Paladin1962 like this.
  13. JD Miller
    JD Miller
    $100 per core = $300 :D
    partsdawg and alanp561 like this.
  14. TorqueMonster1
    TorqueMonster1
    Thank you all for the feedback. No, I did not check any numbers. I knew by looking, of course, that they were Hemis. When I was told the asking price I first had a stroke then I immediately said I’d take them all. The one with Imperial on the valve cover, that’s supposed to be a 392, turns over. I was told it ran when it was pulled out of the car.
    The other two didn’t turn over. At least not with my socket and breaker bar. I didn’t put a lot of pressure on them because I didn’t want to possibly break off a bolt or do damage. Those two were in some type of shed or barn when the man I bought them from acquired them. He had them all under a shed with tarps over them when I bought them.
    I have one more to unload off the trailer into my shop. I’ll try to get the numbers off of them later today or tomorrow and I’ll report back.
    Thanks again for everyone’s input!! Mark
    SS327, Pist-n-Broke, squirrel and 2 others like this.
  15. Paladin1962
    Paladin1962
    Soak 'em in atf and acetone for a month; they'll probably free up. I had an FE 390 that sat under a tarp for a year before I got to checking it out; it was a low mileage reman and didn't need anything
  16. squirrel
    years ago I got a desoto hemi that looked just fine, but it didn't turn. This is why. All the acetone in the world wouldn't fix it.
  17. I've had a couple of engines that wouldn't budge, but after ATF/Acetone squirted in each cylinder and sitting over time, they broke free. Doesn't take much to get them to stick.
  18. Not like squirrel's "stuck"!
    SS327 and 51 mercules like this.
  19. When buying motors that you don't hear run, never pay more than you are willing to watch go up in smoke. I love Hemi's and own several. Lately it hasn't been a good program.
    This little Dodge motor was built for me by a local Friend, Machinist, Drag Racer from way back and known for his Hemi's and Flatheads. Looked dynamite and nothing that concerned me till it came time last Feb to light it up. Wasn't long till it was on the Floor in pieces and the decision to do a total replacement.
    This little Jewel came along with a long list of new receipts and good history of hands on. Never turned with a starter motor and would bolt in,, sorta. I'm in, what could go wrong? You can guess how much $$$ was spent between these 2 motors.
    Apparently, it wasn't enough and this is the same Motor that was Yellow after yet another total going through again by My local builder of choice. He and I have lost track how many motors total he's handled for me personally and my Customers over the years. In this photo it's loaded for Bear, burped and purged and we're both smiling.
    This is it 30 minutes later and the starter motor still hasn't turned it over. I did find replacement heads for this 2 year only motor and I sonic tested them before we started the new machine work. Life is a continuing Education course. Not everything is a good as it looks. Buyer Beware!!
  20. When looking at real old engines, it's wise to ***ume that something was wrong or wore out or they still might be in a car. Anything with moisture in it is going to be trouble with time. I had a y block once that had anti freeze in one cylinder. I was amazed at the amount of damage it did in a short time. Everything has a value. The value for resale may have nothing to do with it's value to you but be careful estimating resale value. The market is always changing. :)
  21. bchctybob
    bchctybob
    My 389 Pontiac was a little rusty and stuck. All of my tricks and all of the ones from here on the HAMB didn’t get it to turn. I dis***embled it a little at a time, tapping things this way and that until I could lift out the crank. I found that the wrist pins were frozen in place and prevented it from turning. Most everything except the pistons was salvageable though, just took a while to get it safely apart.
    1952henry, Algoma56 and SS327 like this.
  22. slayer
    slayer
    I hate to ask, but is the 392 going to be for sale? Dad and I just threw a rod with his 392.
  23. Ziggster
    Ziggster
    Watched this vid the other day. Car/engine was flooded about halfway up the block. Nothing but water came out of the pan drain plug. He thought he would never get it to turn but he did. Still has to tear it down. I guess it’s all part of the fun digging into stuff that was abandoned.
  24. partsdawg
    partsdawg
    from Minnesota
    IMHO early hemi's are one of the greatest drugs in the history of hot rodding.
    People lose their minds when they find them.
    Seasoned car guys lose the ability to use rational thinking.
    First time buyers are awestruck by the look. Gotta have it...it's a HEMI.
    Been sitting outside foe 60 years in the rain and snow? Doesn't matter. Gotta have it...it's a HEMI.
    241 Dodge or 276 DeSoto? Doesn't matter. Gotta have it...it's a HEMI.
    Horsepower to money spent ratio? Doesn't matter. Gotta have it...it's a HEMI.
    I'll admit I still get giddy when I find one in the wild but after a stint in rehab (bought a couple that were non rebuildable for more than s****) I now just try and buy the valve covers and leave the rest.
  25. ras
    ras
    I've bought three Desoto 330, two that were 4 barrel, two had transmissions. They were between $450 - $600 each, all purchased in the last 5-10 years from different people. One was supposed to spin freely but didn't when I got there. Each was roughly a 1-2 hour drive, one-way, to see them.
    One of the three engines had a 2 stuck piston pins. All the ATF and Acetone poured from the top side couldn't help it. So don't be afraid get the engine upside down and fill the bottom side of the pistons with lubricant before getting too involved with a block of wood and a sledge-hammer.
    ras
  26. Guilty, guilty and guilty, but getting better caused by the major increase of cost to bring anything back to life.
    Ziggster, Bandit Billy and bchctybob like this.
  27. squirrel
    it costs a lot less to bring one car back to life, than to bring three cars back to life.
    Pist-n-Broke likes this.
  28. TorqueMonster1
    TorqueMonster1
    I want to thank all of you who took the time read AND especially to respond to my post. Here is an update of what I've found out. As Paul Harvey used to say, "and now you know the rest of the story". The Hemi that's in the first picture that I posted that was a Desoto 330 (as I was told) is actually a Desoto 276 from 1953 (numbers on the block start with S16).
    The 2nd picture was of an Imperial 392. Well its actually a 1957 Chrysler 392 out of a New Yorker, (even though the valve covers identify it as an Imperial). Block numbers start with NE57.
    The 3rd picture was said to be a 354, which would be a Chrysler. Well the blocks number starts with S22. So it's a 1955 Desoto 291.
    The above findings are thanks to the links that were posted on this thread. That said, I'm still comfortable with the purchase from a money standpoint. As I stated earlier, the 392 turns over, the other 2 do not. I read somewhere that Desoto Hemis were difficult to get parts for. I called Hot Heads in North Carolina and was told that everything I'd need to rebuild a short block for the Desotos is available Except for camshafts from them. They mentioned a place that could regrind a camshaft that might also have camshafts if I needed one. Parts for the 392 are available.
    So, with this update what do you all think?? I'm leaning towards tearing into the 392 to see what it looks like inside and starting to soak the Desotos in hopes of freeing them up. I may tear into them also, I just hate to have 3 engines torn apart at the same time. My interest in these is to have a really cool, interesting engine in a hot rod that I'm building. I have, but would rather NOT use, a Cheby 350. I don't need crazy horsepower. I want just want a dependable, reliable, cool and somewhat unusal engine. And I'm leaning towards a manual transmission.
    Thanks Again For Your Input!! Mark
  29. DDDenny
    392/4speed, yeah, that's the ticket!
  30. Ziggster
    Ziggster
    My dream hot rod would be a 32 Plymouth with a vintage hemi.
