I just can't figure it out!
Discussion in 'The Hokey Ass Message Board' started by Bowhunter 53, Aug 25, 2013.
  1. Bowhunter 53
    Bowhunter 53
    I am working on a 53 chevy 3/4 ton project I just bought. It was running when I got it home for a couple of days. After that it died and wouldn't start again. I rebuilt the carb, changed the ignition coil and condenser, and checked the distributor. Nothing. It turns over but won't start. I don't see to be getting spark at the plugs, at least by tester isn't showing spark. Is this an indication of the wires being bad? Or is there something I am missing? I just hate to keep throwing parts at it if its something obvious. Thanks in advance for any help.
  2. landseaandair
    landseaandair
    from phoenix
    Did you confirm fuel to the carb, accelerator pump squirting? Is there power to the coil, do you have a dwell meter?
  3. Bowhunter 53
    Bowhunter 53
    Forgot to mention the truck has a 54 235 in it.
  4. greybeard360
    greybeard360
    Make sure you have voltage to the positive side of the coil (key on).Check the points, check the spark at the coil and at the plugs. Simple matter of elimination, starting at the positive side of the coil !
    I am assuming it has the factory motor and distributor, you never said.
  5. Bowhunter 53
    Bowhunter 53
    The carb is getting gas. I haven't yet tested power to the coil. Would that go out that easily?
  6. Normal Norman
    Normal Norman
    from Goshen IN.
    As landseaandair stated, You need to eliminate the fuel or ignition. One of those is the problem not both, it would be unlikely. Then you can go from there . Plenty of people to help here just ask! N.N.
  7. Bowhunter 53
    Bowhunter 53
    Thanks graybeard. I tested the spark and don't have any at the plugs, nor directly from the coil. Tested the coil by removing wire to distributor.
  8. landseaandair
    landseaandair
    from phoenix
    Yep, bad switch or loose wire.
  9. choptop40
    choptop40
    sure thing , trouble shooting is better than parts changing , check power to the coil , first , then the coil ( primary circuit) then the plugs , if coil is good and no spark to plugs , coil wire is bad , keep us posted....
  10. HOTRODPRIMER
    HOTRODPRIMER
    Or coil. HRP
  11. landseaandair
    landseaandair
    from phoenix
    If converted to 12V, check resistor too.
  12. Bowhunter 53
    Bowhunter 53
    Landseaandair. Thanks I do have a dwell meter (neighbor's), but not familiar with how to use it.
  13. dan31
    dan31
    ^^^ ya, check there and only about $8 to replace
  14. run a jumper wire from your battery positive terminal to the positive terminal of the coil. use this only as a test, as you will be bypassing the ignition resistor.
    if you still have no spark pull off the cap and crank the engine, check to see if the distributor shaft is turning
  15. Bowhunter 53
    Bowhunter 53
    Thanks guys. The coil and resistor are new. I am thinking this may be an issue bore the coil since I have no spark after. It is a 12 volt system. I am going to have to check for power before coil now. My neighbor has a dwell tachometer, don't think that is going to help.
  16. Bowhunter 53
    Bowhunter 53
    Distributor shaft is turning when starter is engaged, and the points as well as the distributor cap look new.
  17. greybeard360
    greybeard360
    Just follow these easy steps... all you need is a test light.
    1: Check voltage at positive side of coil with key on. If there isn't voltage trace back to the ignition swith or as suggested the ballast resistor if it has one.
    2: If you have voltage, put the test light on the negative side of the coil and crank it... see if the light flickers. If it doesn't, look real close at the points, make sure they have a nice clean contact surface between the contacts, with the rubbing block on top of a lobe, set the gap where it should be (.018-.020 will get it running).
    If the points check out OK, make sure the wire from the coil to the points is good... I have seen them break inside the sheathing. (ohm meter works best here).
    Just a hint... I have seen new condensors that were bad out of the box.
    I can tell you how to test it... but it would be best if I didn't.... can be a little rough. :)
  18. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Crawl under your dashboard and look at the ignition switch wiring. I bet your "start" wire is either disconnected or corroded/not sending a 'start' signal to your coil. Happened on my '48 chevy. Same symptom. It could also be a bad ignition switch.
  19. Bowhunter 53
    Bowhunter 53
    Hey guys. Thanks for all of the insight. After testing everything I could think of and replacing some parts (which were old anyway), it turned out to be the ballast resistor. Now I need to adjust the choke and throttle. Thanks again for all the help!
