Hot Rods I know it's been posted in the past but it's so dadgum cool
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Jan 6, 2017.
  1. I did a quick search but didn't see it but I'm sure it's been posted in the past,but like I said and to paraphrase the late 3wLarry , " It's so DADGUM cool". HRP
  2. rooman
    rooman
    Bloody Scandanavians!!!
    Roo
    HOTRODPRIMER and falcongeorge like this.
  3. are those wooden wheels?
    HOTRODPRIMER likes this.
  4. Finnrodder
    Finnrodder
    from Finland
    Thats Juha Kankkunen's model A.He is a finnish world rally champion,so i guess thats one reason for the Ford BDA motor...
    Those are an aluminum wheels,that have wood graining painted on them.
    HOTRODPRIMER and lothiandon1940 like this.
  5. Sounds like an Alpha Veloce at Monaco. :D
    HOTRODPRIMER and scrap metal 48 like this.
  6. oj
    oj
    That must have the sound track dubbed. It sure didn't feel that we went as fast as that engine went, but its' a hoot for sure!
  7. Now that is a Hot rod!
    Ben
    Montana1 and HOTRODPRIMER like this.
  8. dave plmley
    dave plmley
    Every time I see this I'm amazed. Great car.
  9. DDDenny
    That would be sooo much fun.
    I saw a magazine article about this car after it was first built.
    Real hot rods are still alive and well.
    Bravo!
  10. gnichols
    gnichols
    from Tampa, FL
    There was an old thread that had details on this car, but who knows if it's still recoverable. I remember the article, but can't remember the magazine it was published within. The wheels looked like wood but were custom cast. Talk about a cool sleeper! Gary
  11. maplefrm
    maplefrm
    from Central IL
    That was GOOD.
  12. rooman
    rooman
  13. oj
    oj
  14. There was also a vid of the build up somewhere.
  15. gnichols
    gnichols
    from Tampa, FL
    The AU article also provides a link to the builder's pix and refs the Mar 2008 Hot Rod Mag article. I think the model A guys should take a look at that tricky chassis! The still pix are great to see. Gary
    http://www.mat.fi/projects/68
  16. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    just fun vid.
  17. Last edited: Jan 6, 2017
    dana barlow likes this.
  18. steinauge
    steinauge
    from 1960
    Way cool! Thanks for posting.
  19. SPECS
    OWNER: Juha Kankkunen
    VEHICLE: 1929 Ford Model A
    PAINT: Custom mixes of PPG 2-pack (brown, tan and black)
    STYLING: Intended to look standard
    ENGINE: Cosworth BDA 4-cyl (Group 4 Escort), now 1991cc
    ENGINE MODS: Alloy block (90.4mm bore), Cosworth billet steel crank (77.6mm stroke), Cosworth forged rods, Cosworth flat-top pistons, 11.5:1 static comp’, multi-layer steel head gasket, ported Cosworth 16-valve head (47cc chambers), stainless valves (1.4in intake and 1.2in exhaust), Cosworth L1 cams, belt drive hidden under custom steel cover, Cosworth double valve springs, dry sump (tank in rear trunk, along with battery), Cosworth intake manifold, Jenvey 45mm throttle bodies (two twins), custom classic-look air cleaner cover and plenum, Bosch 450cc/min injectors, Jenvey fuel rail, Bosch fuel pressure regulator (6bar), Bosch fuel pump, Hestec multi-point EFI (stand-alone ECU, switch on gear knob to make it misfire a little and sound like the original motor), EFI wiring hidden under custom valve covers, Bosch Classic Wires ignition leads, NGK Racing 10 spark plugs, Lucas alternator (disguised as dynamo), brass-coloured fittings
    Power: 248hp@8200rpm (flywheel power calculated from Bosch chassis dyno)
    Performance: 0-100km/h in 5.8sec
    Exhaust: Custom 2in long-tube 4-into-1 headers, single 3in system with Simons centre muffler and custom rear muffler (1.5in outlet tip and large cut-out at bottom)
    Gearbox: 1981 ZF short-ratio 5-speed (Group 4 Escort, 3.42:1 first, 1.94:1 second, 1.39:1 third, 1.25:1 fourth, 1:1 fifth), Magnesium bellhousing, sintered double-plate clutch, steel flywheel, custom gearshift
    DIFF: 1988 Toyota 4x4 van, Toyota Racing Development (TRD) LSD, TRD axles, 5.8:1, TRD driveshaft
    SUSPENSION: Original-type cross-leaf front spring (lowered 50mm), Girling adjustable lever-type struts (from Aston Martin DB4), reinforced original A-arm, rose joint, brass bushings, adjustable 20mm front anti-sway bar, rear leaf springs (lowered 70mm), Girling adjustable lever-type shocks from Austin Healey 3000, rose-jointed four-link with Panhard rod, adjustable bump stops
    BRAKES: Toyota hydraulic drums (330mm front, 290mm rear), Tilton bias-adjustable pedal box, two Girling 21mm master cylinders (no booster), hydraulic handbrake (“for handbrake turns”)
    WHEELS/TYRES: Custom cast aluminium 19in wheels (spokes covered with polished wood-grain), 5in Dunlop Racing tyres (vintage style)
    Interior: Restored original seats, custom Moto-Lita steering wheel, Simpson 4-point belts (can be hidden under seat pillows), LCD data logger display hidden above windscreen
    WEIGHT: 1050kg (without occupants), 45/55% front/rear weight distribution
    ANYTHING ELSE: Extensive chassis mods (boxed rails, custom cross bracing)
    COST: “Enough to be the most expensive Model A in the world”
    THANKS: Kari Makela and Makela Auto Tuning (MAT) in Finland
  20. Hotdoggin DaddyO
    Hotdoggin DaddyO
    from Hays, Ks
    That is so cool on so many levels. I wanna hang out with that guy. Thanks for posting. Man, I can't stop grinnin'.
    mgtstumpy and HOTRODPRIMER like this.
  21. You and me both! HRP
    mgtstumpy and Montana1 like this.
  22. It can pull the inner front wheel off the ground while on the skid pad and not roll over on itself. Nuts.
  23. Well ,that was a nice relaxing sunday drive!:p
  24. Montana1
    Montana1
    WHOA!!! I was not expecting that! :eek:
    Here is a follow up video that came up afterwards...
  25. BrerHair
    BrerHair
    A wolf in sheep's clothing, so cool. Man I love sleepers!
  26. Good video ~ As long as the volume is muted! :rolleyes: HRP
  27. 55willys
    55willys
    That is quite a piece of engineering.
  28. Montana1
    Montana1
    Yes! I wish they would put on some decent music. :rolleyes:
  29. No joke,I know I'm old but that sucks! HRP
    Montana1 likes this.
  30. mgtstumpy
    mgtstumpy
    I've seen it before and it's still way cool. I'd love to be standing there to hear and see it fly by driven by someone better than me. It's as aerodynamic as a cinder block with high centre of gravity however he drives it like an MG. Awesome:p:D
