I need a Model A frame!!!
Discussion in 'The Hokey Ass Message Board' started by dukes26, Nov 28, 2010.
  1. dukes26
    dukes26
    from CO
    Hey guys,
    Anyone know who makes a nice Model A frame and is good to deal with? I have an original frame, but honestly I don't want to go thru the hassle of extending it & boxing the rails. And I don't want to run '32 rails, just a simple stock-looking frame for my roadster. I'm in Colorado and have heard horror stories about Riley Auto & Last Refuge. What do you guys think? Thanks for the help
    dukes
  2. Why do you need to extend it? Just box it and put the body on.
  3. dukes26
    dukes26
    from CO
    I'm running a small block, so I need a few extra inches between the radiator and the firewall.
  4. JimA
    JimA
    A or '32-style Frame? I can get either for you from SO-CAL at the best price. OOPs, missed the one line about '32 frame.
  5. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Why not just buy 2 peices of tubing and reuse the dimensions and crossmembers you have ,That is the same shape 2 x ,You would need 1/8 inch minimum .And graft front horns in .......Cost 80 bucks and labor .I hope you can weld ....
  6. Kustom.Falcon
    Kustom.Falcon
  7. andysdeuce
    andysdeuce
    Why do you need to box the "A" frame?? Why don't you just put a "K" member in it for the tranny and a "X" frame in front of the rearend for added strength. Use what you have and save some money for other things.
  8. Troyz
    Troyz
  9. Talk to your DMV about registration. Using a stock frame with an original number might make your life easier.
    Charlie Stephens
  10. NoSurf
    NoSurf
    What about a AA frame? Tall like a '32 frame. Long as heck so you can cut it off at the back where you need it. They are much thicker/stronger than a '32 or A frame. And they are relatively cheap.
  11. Framewelder
    Framewelder
    Give Thunder Road Rod & Custom a call. We can do you a frame anyway you like. Our Model A's are all lazer cut out of one piece of material (front horns are not added on) They come with all body mounts and nuts welded on.
    419-522-4712
    www.thunder-rods.com
  12. Von Rigg Fink
    Von Rigg Fink
    from Garage
    funny...I didnt lengthen mine any:confused:
    kick your firewall back in a few inches
    usually when they are "made longer" they end up looking all wrong, proportions get off..
    not too many guys can pull that off too well
  13. Von Rigg Fink
    Von Rigg Fink
    from Garage
  14. -Brent-
    -Brent-
    I've seen a few frames in the classifieds, not stock frames... there was a Bleed Swept frame and another box tubing A frame not too long ago.
  15. Kustom.Falcon
    Kustom.Falcon
    These threads are funny. Everyone's got an opinion, and no matter how good it is, they'll all be overlooked.
    It's at least worth a call to this guy: www.bolingbrothers.com
  16. here ya go already
    http://www.jalopyjournal.com/forum/showthread.php?t=481104
  17. willowbilly3
    willowbilly3
    from Sturgis
    I started out with an A frame. Then got to looking at the amount of factory holes that need filled, boxing ect and decided to go a different way. I had a couple broken junk A frames and used the rear sections, welded the horns on and built everything from the toe boards back from tubing. The rear sections have the same taper and way fewer holes to fill. So now the part that shows is stock looking A frame with a lot less work and I only had to box the front section.
  18. t-buckethead
    t-buckethead
    from texas
    mine is a speedway frame,looks just like a tci,cost 1995.00 everything there
  19. pitman
    pitman
    If you have a Lincoln "juke-box" welder or better, get (3) 10' lengths of 2x4x3/16th in steel tube and build it! Just copy the A dimens. Idiot stick rod (7018 & 7024) and you'll be done in three days. Lay the front crossmember tube down,(or cut and use the stock front X-member) and at the side rail mid point, cut the ~three sawblades thick vee's and bend the tube outward, use this weld joint as the centered mount location for the center X-member or tube, then use trimmed "ears" of the rear member tube to cap the side rails at the ends. [the image is from '73, scanned]
    Frame horns are formed by cutting a curved wedge out of inner and outer faces of the side rail (forward end) and hammering down the top face...weld the seams and cap the remaining 1-1/2".
  20. Eric at Riley Automotive is a good guy. If you are close go by and see what he can do for you. I don't recall ever seeing a post on this forum knocking one of the chassis he has built. Eric has a lot of satisfied customers. I'm one of them.
  21. Yeah, these dudes are sick.
  22. I'd go the make your own route, you can get the dimentions here;
    http://www.wescottsauto.com/WebCatalog/FrameDiagram1928-31.pdf
    There was an article in Street Rodder years ago. Can't remember the exact issue, but it was an intro to TCI and they showed how they make them from 2X4" 1/8 wall tubing. Very simple. Here is mine.
    Let the welding begin_Both rails are ready to go now_Project has been on hold for a couple years.jpg Cutting new frame rails out of 2 by 4 inch rectangle tubing.jpg
    It would be simple to add a couple inches to the original length.
  23. not to high-jack fellas but do you guys think a stock A frame not fully boxed but is boxed in the motor mounts, and alot were the tranny crosmember bolts in and has a large supportd welded above the tranny strong enough for a weak small block? its just a driver.
    i havnt seen to much info on what is enough or not.
  24. if you're going to take all that time, just box the whole thing. Take ya about twenty minutes longer.
  25. haha i hear ya rjp. well im not realy able to get the body all the way off now. i was hoping it was enough strength with what i got. it seems solid, but it doesnt hurt to ask the experts
    forgot to mention its also boxed were my wishbone mounts hang in the front and back. im just worried about this 'x' member iv been seing alot of now
  26. willowbilly3
    willowbilly3
    from Sturgis
    Lots of guys have got by without boxing. I have never actually seen an unboxed frame fail, although I'm sure they have. I think you could get by fine with just the front boxed on a mild street engine.
    RJP, 20 minutes to box the back half of the frame? Well, maybe if you had the rails clean, laid out and factory store bought boxing plates so all it took was a few extra welds.
  27. Framewelder
    Framewelder
    Here are some pics of a Thunder Road Rod & Custom base perimeter.
    811 Park Ave. East Suite D
    Mansfield, OH 44905
    419-522-4712
  28. Von Rigg Fink
    Von Rigg Fink
    from Garage
    boxed and X member..not twisting with any power plant
  29. VAPHEAD
    VAPHEAD
    We do custom type hot rod frames for A's
    (rolling chassis' too)
    Gladly answer questions via PM's
    I'll attach some pic's,customers cars
    looks like most guys channel the body...(you don't need to)
  30. edwardlloyd
    edwardlloyd
    from Germany
    Yeh you're also banned from the HAMB for life Eric for ripping people off including myself and Bob Wilson so I reckon you should set us straight before taking anyone elses money eh!
    Ed
