I need a second opinion
Discussion in 'The Hokey Ass Message Board' started by Shaner's74, Nov 18, 2013.
  1. Olderchild
    Olderchild
    from Ohio
    GOOD!!! call me crazy but i like to adjust my lifters after the engine is hot and while it's running others will say it a waste of time i'm sure (to those:p)
  2. Russco
    Russco
    from Central IL
    Yes, the valves were adjusted a little too tight so they were not closing fully = no compression in a few cylinders = wouldn't start.
  3. aonemarine
    aonemarine
    from Delaware
    Better to catch it now than after a few miles...exhaust g***es can cut thru stuff just like steam...
    Im still not done bustin his balls yet though, just trying to find a way to do it in good taste...:p
  4. Russco
    Russco
    from Central IL
    I'm using Morels(hyd roller) in the 383 I'm building now. They are really nice but they set up a bit different. They come from the factory filled with some type of light oil. I put them all in and tightened the lash up to squeeze out the oil they were shipped with. Then I soaked them in a good 10W30 oil then set lash as directed.
  5. aonemarine
    aonemarine
    from Delaware
    Hmm, light oil.... sounds like my honing tank oil....or grinding fluid...
  6. woodbutcher
    woodbutcher
    :D RE: DDCoopman.Just saw the thumbnail that you posted.I just about choked on my iced tea.That is a spittin image of a sweet old kitty that we had about 10 years ago.Right down to the expression.Thanks for the memories.
    Good luck.Have fun.Be safe.
    Leo
  7. Rickybop
    Rickybop
    aonemarine goes to the head of the cl*** and gets a gold star on his forehead from Miss McGillicuddy....along with Olderchild, tjet, telekenfun and Rusco. (hope I didn't miss anyone) And lots of good input from 31Vicky with a hemi and others. But I think aonemarine was the first to say "pumped up lifters." (pg. 2) Sounds like Vicky's method of pre-pumping the lifters before installation is plenty worth the time and effort.
    Glad ya got 'er straightened out, Shaner's74!
    Again...I learned (and re-learned) some stuff here.
    Good one, guys. As usual, the Hamb rocks and rolls.
    Cl*** dismissed. Next week, we'll study intermittent loss of spark. :D
  8. DD COOPMAN
    DD COOPMAN
    I've pre-soaked and pre-pumped new lifters in a coffee can forever in the past. Can't remember who taught me that. Good advice, anyhow. DD
  9. Shaner's74
    Shaner's74
    I presoaked and pumped up the lifters on this engine.
  10. swade41
    swade41
    from Buffalo,NY
    I still want to know how you are checking the timing without it running ? If you are pointing the rotor at number one and hope you are in the ball park then I can live with that.
  11. McGurk
    McGurk
    from Mid West
    I replaced a countless number of camshafts and lifters in all of the different Chevrolet engines when I worked as a mechanic at two different Chevrolet dealerships. I popped open a can of GM EOS and coated the camshaft and lifters and in the engine they went. When adjusting the lifters I rotated the engine to TDC #1 and static adjusted the lifters on IN 1257 and EX 1348. I rotated each push rod with my thumb and fore finger in order to detect zero lash. The spring in the lifter will prevent rotation. After completing that phase I rotated the engine 1 full turn clockwise and adjusted the remaining lifters using the same technique. After completing the second phase I went down each bank and tightened the adjusting nuts down a half of a turn. I prided myself in building an engine that would start and run as it was ***embled. The lifter clatter was barely detectable. That is very common behavior a****st engine builders because an engines first few second can effect the engines overall life expectancy.
  12. henryj1951
    henryj1951
    from USA
    :cool:
    happy holidays
  13. 66tintop
    66tintop
    from Canada
    Have you ever hooked your battery up *** backwards ? If you had , and tried to crank it over , then you have fried your msd box right awAy , just asking !
  14. I really have no idea besides guesses.
    But Something went wrong for you here.
    Like I said before is not mysticism, it's methods
    The compression test method you originally chose to use led you and the thread on a different path than it should have. Eventually it found its way but took the long way home. Sometimes the scenery is nice.
  15. aonemarine
    aonemarine
    from Delaware
    LOL no, I have reverse rotation starters......:D
  16. This method is fantastic with the following caveats
    1 You are certain the lifters are quality units
    2 you get paid by the piece to put the egnine together once , and by the hour if there's a problem.
    Since the influx of **** for lifters I can't see myself ever doing it this way again.
  17. Shaner's74
    Shaner's74
    Exactly. That is the only way to set initial timing. Once it's up and running you can put the timing light on it.
  18. Shaner's74
    Shaner's74
    Who?
  19. tjet
    tjet
    FWIW, I always use Johnson lifters, but they are not cheap. I think they are the only US made lifter. For my hemi I was quoted 12 ea for hyd flat tappet
    http://johnsonlifters.com/Products.aspx
    I've also used Crower Camsavers too
    http://www.summitracing.com/search/...rower-camsaver-hydraulic-lifters?autoview=SKU
    One more thing: I never soak them. Put them in empty & check oil flow thru the pushrods during the pre-lube procedure
    Anyway - glad ypu got it running (cheers)
  20. Steve!
    Steve!
    from at the gym
    I could use some johnson lifters too anymore
  21. Olderchild
    Olderchild
    from Ohio
    It' soooo easy to get lost while adjusting lifters(for me any hoo:eek:), ah lets see i just did #3 intake dah didn't i, ah **** here we go again,back to square one:mad: I'm easily distracted and it a curse
  22. aonemarine
    aonemarine
    from Delaware
    LOL..... "Paint marker" :D
  23. Me too
    the phone rings- the pizza guy shows up, the neighbor stops by to BS, the old lady wants to play grab ***, the dogs gotta go Pee , you gotta Pee, ***embly lube tube got clogged, the cut you got yesterday starts bleeding again, and you can't find the damn paint marker.
  24. tjet
    tjet
    http://www.youtube.com/watch?v=fJsnR-KDbFc
  25. HOTRODPRIMER
    HOTRODPRIMER
    Static timing is my guess. HRP
  26. henryj1951
    henryj1951
    from USA
  27. Olderchild
    Olderchild
    from Ohio
    YA! So you guys can embarr*** an old amateur like me:p
  28. theHIGHLANDER
    theHIGHLANDER
