I need a shock mount stud......
Discussion in 'The Hokey Ass Message Board' started by Roothawg, May 5, 2009.
  1. Roothawg
    Roothawg
    You remember those things that used to be free with every shock set? Apparently, those are overhead because you can't find them now.
    I had one from a previous shock set but I can't find the other one.
    It's a 1/2-20 stud with a 5/8" shoulder for a shock with the eye. I bought the shocks we were discussing on a previous thread.
    http://www.jalopyjournal.com/forum/showthread.php?t=358347
    I talked with both parts stores in the area and they looked in all their books. No luck. The shocks I ended up with were the Monroe 5752. That's the shortest shock I found in a production shock.
    Parts guys to the rescue.
  2. Crusty Nut
    Crusty Nut
    I last got some at the local tire/brake/shock store. They would even let me pay for them.
  3. Goztrider
    Goztrider
    from Tulsa, OK
    The last set I got came out of a set of shocks I purchased. They were for the rear of a chevy half ton truck - think 80s model. My buddies at the parts store pulled'em out for me and defected the boxes and sent'em back.
  4. LUX BLUE
    LUX BLUE
    Alliance Vendor
    from AUSTIN,TX
    check out the "help" section at autozone. it's the only place I can find them on a regular basis.
  5. OLLIN
    OLLIN
    I know socal speedshop has them, I just bought some. They were like $20 though! for polished stainless
  6. ROCKET88COUPE
    ROCKET88COUPE
    from TEXAS USA
    ck out a used harley shop near you made all diff sizes for sporties and big twins
  7. llonning
    llonning
    Monroe part #'s for 1/2 thread CP1, CP2,CP3, CP4.
    They measure the shaft length from 1/2 way in the ring mount to the backside of the stud mount.
    CP1 1-1/16
    CP2 1-3/16
    CP3 1-5/16
    CP4 1-1/2
    Hope this helps, if any questions the specs are in the Monroe on-line catalog under misc info .
  8. LowFat48
    LowFat48
    look for shoulder bolts at the hardware store..... I don`t know if they make them in fine thread though.
  9. larshere
    larshere
  10. Also used to come with 63 Chevy half ton shocks.
  11. Bphotrod
    Bphotrod
    from da U.P.
    Went through same thing myself a few weeks ago. If you cant give the clowns behind the counter a year make and model your out of luck. I remembered I had a mid 80s Chev truck that the shocks came with those studs as mentioned above.
  12. Roothawg
    Roothawg
    Thanks guys. I should have tried to get them BEFORE I built my brackets. I'll check out all of the leads I have here.
  13. Kustomz
    Kustomz
    The mount at the Speedway link above is available at OReilly's in their HELP display.
  14. Roothawg
    Roothawg
    Not at our O'reillys. It was a 1/2" bolt with some lame washers.
    I can have stuff here the next day with Speedway. It's amazing how fast it gets here.
  15. George G
    George G
    Same thing with those dimpled washers. Where can they be found?
  16. They came with the shocks I bought for my '64 Chevy truck. I think they were Monroe's from O'reilly.
    I probably have 6 or 7 pairs in my toolbox.
