I need a torch...
Discussion in 'The Hokey Ass Message Board' started by Harrison, May 23, 2004.
  1. Harrison
    Harrison
    ...but don't know anything about them. Never even used one.
    I want something that I can use to cut and heat with. I have a welder already. A small set-up would be nice so I can easily travel with it to the junkyard.
    Lowes has a Harris kit for $269 with two tanks included but there is no rosebud tip in the kit.
    Then I found this on Ebay...
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=11774&item=3816345103&rd=1
    Would this work for me? It will do only light work and will be used rarely - I don't want to sink a fortune in a kit.
    Thanks, JH
  2. Upchuck
    Upchuck
    from Canada BC
  3. Harrison
    Harrison
    [ QUOTE ]
    it states no brand name just as "imported" so parts might be hard to come by or expensive,
    [/ QUOTE ]
    ...or total*****. That guy's feedback was a mess too.
    I looked at the other thread and found a link to the Ebay store for IOC Welders. They have a portable Victor set with tanks for just $20 more. I hit the "Buy It Now" and it should be here by the weekend.
    Thanks, JH
  4. A big Rosebud will drain a small tank setup FAST! I would get the biggest tanks you can. Nothing worse than running out on a Saturday night when you need it most.
  5. Deuce Rails
    Deuce Rails
    Sears sells a similar kit, and it's easy to go back to them if something's not right.
    Almost no starter kit includes a rosebud. They're not cheap, either.
    If you get a good Oxy-Acetelyne outfit, you can do almost anything.
  6. Crestliner
    Crestliner
    Don't buy the small ones. You'll be spending to much time and money filling tanks. Been there done that.
