Technical I need advice
Discussion in 'Traditional Hot Rods' started by jerryt, Mar 8, 2023.
  1. jaracer
    jaracer
    A properly wired ammeter tells if current is flowing into or out of the battery. As long as current is flowing into the battery, it is being charged. A voltmeter give you a better idea of battery condition along with indicating the charging system is working.
    lake_harley and sunbeam like this.
  2. scoop
    scoop
    Coming from a guy with a ratrod in his name and avatar.
    Atwater Mike likes this.
  3. sunbeam
    sunbeam
    If you have a properly installed and sized amp gauge and wiring every thing is fine and it offer on time info. It will till you if you are producing more or less power than you are using with a volt meter you only know if the voltage keeps dropping. In most cases factory generator systems are not heavy enough
  4. Volt meters have been around and being used in cars since before the war. I screwed a '40 chevy together in '70 granted that was after '65. The old guy I got the car from had a box full of military and SW curved gl*** gauges, volt meters in both.
    AMP meters came stock in cars as well as idiot lights. Hot Rodders upgraded, well the real ones did.
    firstinsteele and joel like this.
  5. saltracer219
    saltracer219
    Did you learn something you diden't know before?
  6. hot-rod roadster
    hot-rod roadster
    from Omaha Ne.
    Yep
  7. BJR
    BJR
    The problem with amp meters is if you have one that only goes to 30 amps and put an alternator in the car that has a 150 amp output you overload the amp gauge. Then fire happens. Most amp gauges were made for cars with generators, that put out a maximum of 30 amps. We update the car with an alternator and overwhelm the system.
    Beanscoot likes this.
  8. Kerrynzl
    Kerrynzl
    All current flows both ways through the ammeter [except the main battery cable to starter]
    The ammeter usually can only handle about 35A to 40A of current [which is why they are feared and often byp***ed] This 35A is enough for normal everyday use, but the problem occurs when a 60A - 100A alternator tries to charge a car that has flattened the battery
    You add a "Diode Shunt" [Hybrid Shunt] that byp***es the ammeter when it is "ma**ed out"
    But under normal cir***stances the shunt is closed and the ammeter reads like normal. [and the Alternator is only charging enough for maintaining the battery]
    Also if the ammeter fails the shunt will take the current and not leave you stranded on the side of the road.
    A diode shunt doesn't behave like a resistor shunt [which alters the values of the ammeter]
    Atwater Mike and BJR like this.
  9. blue 49
    blue 49
    from Iowa
    I haven't used an ammeter since the one in my 3 gauge under dash panel started to smoke and meltdown in a pretty basic, 283 powered truck. It had an alternator of unknown output, but I was just cruising down the road at the time. I stopped on the side of the road and connected both leads to the same stud to "fix" it.
    Gary
  10. jerryt
    jerryt
    Hi. First I want to apologize. My wife got tired of me tearing up the garage and always on the computer looking up ammeter. So she bought me one and now it’s in my 26. So thank you for all the advice. My wife just said buy another one and that’s what she did.
    Thanks
    Jerry
    pprather and rc57 like this.
