i need advise
Discussion in 'The Hokey Ass Message Board' started by speedysilver, Jan 16, 2010.
  1. speedysilver
    speedysilver
    hey
    I was told today if i found out what rear-end i needed for my ford 23 t bucket im building before early next week i could get my rear-end for free. i am looking for a narrow rear-end with perferably a 5 on 5.5 bolt pattern. any advise is welcome.
    thanks
    mikey
  2. davidwilson
    davidwilson
    from Tennessee
    early 60's ford step side pickup
  3. LIL.TIMMYUser Name
    LIL.TIMMYUser Name
    if you really want to step-up. use a 65-72 type ford f-100 dana 60. most were 3.54 posi rears. cheap and common.
  4. roddinron
    roddinron
    Son, I've been around a while, and one thing I've learned is there's no such thing as free rear end.
  5. speedysilver
    speedysilver
    my dads payin for (im 16) it will be free for me...
  6. Hnstray
    Hnstray
    from Quincy, IL
    You missed the point :D 'rear end' ..........tail........wiff.........**** tang.....all old terms...........ask your Dad.....
    BTW the Ford step side rear axle is the same as the styleside...the bed is different, not the axle. How narrow does it need to be? 5 on 5 1/2 is not all that common outside of Fords, except for some Jeeps and IH Scouts, and they may be too narrow.
    Have you determined yet what wheels and tires you are going to use on the rear? If so, then set them up next to the body with the spacing or clearance you want between the tire and body and measure from the inside mounting surface of one wheel to the other and that is the width rear axle you need. You may find it is very close to a stock dimension axle, but in any case it will be useful indormation.
    It is also possible to have axle shafts redrilled for the bolt pattern of choice, although going bigger to 5 on 5 1/2 may pose a problem. Thinking outside the box, here, but Toyota and Nissan 4x4 pickups, and some other Japanese SUVs used 6 on 5 1/2 and they would have large enough axle flanges to redrill to 5 x 5 1/2. There is also the possibility of having axle shafts made in whatever width and/or bolt pattern you need if you can't find a stock set up that works.
  7. swade41
    swade41
    from Buffalo,NY
    The early ford bronco up to 76 is what you're looking for, right width and bolt pattern. The 6 cyl. will have a 4.11 gear and the V-8 will be a 3.50 ratio. That's what I'm running but not that easy to find.
  8. 56don
    56don
    Ha ha. So true brother, so very true!
  9. 32SEDAN
    32SEDAN
    Don, I like your new avatar. New project? Still have your '56?
  10. mart3406
    mart3406
    from Canada
    How 'narrow' does the rearend need to be? If you
    need one *substantially* narrower than either the
    standard Ford pick-up or Bronco rears (both good
    choices by the way) that others have mentioned,
    you can build a really narrow rearend for cheap, by
    using a 9 inch rear from a 1970's-era Ford Econoline
    Van. These had an offset center section and by
    shortening the one long-side axle tube to center
    the center section and using two stock short side
    axles, you can end up with rearend with a width
    of about 46.5 -47 inches wide.
    Mart3406
  11. 6cyl / 4.11 is the way to go... strong and common... good luck with your build... hope your dad can score you a decent rear end! - no pun intended...
  12. 333 Half Evil
    333 Half Evil
    Yep, early small broncos are the best fit. That is what I'd look for if I were you. Post pics of the build as you go.
  13. Royalshifter
    Royalshifter
    Moderator
    Early Ford Bronco is perfect.....1968?
  14. Sphynx
    Sphynx
    from Central Fl
    Thats what I used it was perfect , come out of a 77 bronco .
      541.1 KB
