i need help from the ford truck guy!!!!!
Discussion in 'The Hokey Ass Message Board' started by kryptic phinishes, Nov 13, 2009.
  1. kryptic phinishes
    kryptic phinishes
    from kansas
    i have a 64 ford f250. i am trying to get it more driveable and low at the same time. what is the difference between the f250 and the f100 frame?
    any thing will help here
    thanks
  2. trailer-Ed
    trailer-Ed
    from JC, MO
    chassis are the same, suspenion and rearend and brake/ lug pattern are main differences.
  3. R Pope
    R Pope
    Hubs, drums and backing plates off an F100 will fit the front, a rear end swap will fix the other end. I did it on my Uni 250.
  4. kryptic phinishes
    kryptic phinishes
    from kansas
    thanks that is good to know
  5. kryptic phinishes
    kryptic phinishes
    from kansas
    so the 03 crown vic front end will fit a f250 then?
  6. il Revrunde
    il Revrunde
    If you're asking if the "track width" is the same, best bet is to get your tape out and measure hub to hub. the suspension is completely different as your 250 has either a solid axle or I beams. A later f150 would be more suitable if you have I beams. Ideally, a solid axle is the way to go if you're lowering it, and a steering stabilizer will get the bumpsteer down significantly. If memory serves, crown vics have a control arm setup and if you want to swap it in you're gonna have a job ahead of you. I wouldn't bother, but thats just my $.02:cool:
  7. il Revrunde
    il Revrunde
    Rear is easy. Get rid of the helper spring and add blocks.....and shorter shocks.
