i need help. how do i get a stuck brake drum off
Discussion in 'The Hokey Ass Message Board' started by ozzies 57, Apr 27, 2013.
  1. ozzies 57
    ozzies 57
    I bought a 45 ford. The drivers brake drum in the rear is locked up. I winched it onto a trailer and the wheel wouldn't break loose at all. I already tried the hammer the **** out of it method and prying off the backing plate. There has to be a better way to get a stuck brake drum off. Plese help.
  2. tfeverfred
    tfeverfred
    Did you loosen the shoe tension on the inside? Then... BFH.
  3. ozzies 57
    ozzies 57
    I tried to it is stuck too!
  4. roughneck424
    roughneck424
    Yep
    You've tried the usual steps to remove the drum with no success. Now it's time to get serious. Heat the surface around the hub and lug holes with a torch, one of those propane jobs for sweating pipes works well. You need to get it hot, not red hot, but close. Once it's hot, smack it with a hammer,
  5. 57countrysedan
    57countrysedan
    from NY
    I ran into this with a 46. It got serious. Heat didnt work. Had an old drum puller that didnt work. Had to cut the drum and hub off.
  6. Rickybop
    Rickybop
    Avoid using the hmmer, unless you don't care about saving the drum. You can break it or chip a nice big piece off the edge. It's always best if you can adjust the tension off, but if you can't, first grind the heads off the pins that secure the shoes to the backing plate. (back side) Then use 2 or 3 wedges of some sort...big screwdrivers, small crowbars, etc. With the pins out, the shoes will pull away from the backing plate and probably come off with the drum.
  7. ozzies 57
    ozzies 57
    I'll try the heat first. I got propane one. And a BFHammer. Any other tricks are welcomed.
  8. hotrod40coupe
    hotrod40coupe
    You need one of these.
  9. Rickybop
    Rickybop
    The shoes won't actually come off, but will pivot away from the backing plate and allow the drum to come off. Pull on the crowbar that's near the middle of one shoe.
  10. ChopTopJimmy
    ChopTopJimmy
    What exactly is this? CTJ
  11. pinkynoegg
    pinkynoegg
    how exactly did you hit it with a hammer? the best method i found was to hit it directly on top and on the sides. don't try to hit it from the back and push it out
  12. hotrod40coupe
    hotrod40coupe
  13. edhd58
    edhd58
    from kentucky
    I had the same problem on my 42 Ford. I used a small 3 jaw gear puller. It worked just fine. Tighten it up good, hit the end of the puller with a hammer and it popped right off.
  14. Pops1532
    Pops1532
    from Illinois
    Heating,prying,hitting with a bfh,pullers, grinding the heads off the anchor pins almost always work. I had a slightly OT car that the rear brakes were so froze/rusted up none of those things worked and I had to cut the drums off with an angle grinder.
  15. 1951Streamliner
    1951Streamliner
    from Reno, NV
    One time I was trying to pull a drum off a 54 Cadillac.
    I thought it was stuck, tried everything to get it off....
    Turns out the parking brake was engaged... so.. check that first haha :)
  16. You are aware that the Hub and Drum are on piece so in order for the drum to come off you need the Axle Nut off and to brake the taper lock of the Axle to Hub at the same time. Just thought I'd put that out there just in case.
    The Wizzard
  17. JohnEvans
    JohnEvans
    from Phoenix AZ
    Yep you need to pull the hub and the drum will come with it. Do NOT pull on the OD of the drum as all that will do is ruin the drum and it still won't be off. Do a search as there are many threads on here dealing with the correct way to remove the hub/drum ***y.
  18. Texas Webb
    Texas Webb
    Find someone in your area in the early V8 club with a puller,and put the nut on backwards so not to ruin the axel threads.Might use heat also.
  19. 40FordGuy
    40FordGuy
    Use that puller...it'll come right off. It catches the groove on the hub snout,.. DON'T use the kind that pulls on the lug studs,...the drom will bend, and the hub remains stuck.
    KRW still sells a repop of the Ford dealer shop item....well worth buyin one.
    4TTRUK
  20. chinarus
    chinarus
    from Georgia
    If you have a an air chisel with a hammer head that might generate more vibrations to break any internal rust bonds than a BFH. Best you can do with a BFH and a normal arm is probably a couple of minutes worth hammer blow vibrations.
  21. JohnEvans
    JohnEvans
    from Phoenix AZ
    Gee ya telling me I've been doing it wrong for the last 50 years pulling hubs/drums with a stud attached puller ??? Must have pulled a couple of hundred and ain't bent a drum yet. Ya do need the puller made to do it that way though.
  22. ozzies 57
    ozzies 57
    What is taper lock? I did realize you have to take the nut off thank god.
    UOTE=Pist-n-Broke;8858728]You are aware that the Hub and Drum are on piece so in order for the drum to come off you need the Axle Nut off and to brake the taper lock of the Axle to Hub at the same time. Just thought I'd put that out there just in case.
    The Wizzard[/QUOTE]
  23. Engine man
    Engine man
    from Wisconsin
  24. Correct info above as Engine Man says. The Axle to hub is a machined tapper like a Ball Joint or a Tie Rod only it's about 3" long with a Key Way. You can't just take the Nut off and take the B.F.H. to it. You need a correct puller as you have read. In fact you may not have a Brake Shoe issue at all. You could have a problem in the Differental preventing the Axle/Drum from turning at all.
    The Wizzard
  25. edhd58
    edhd58
    from kentucky
    My puller is a small 2 ton effort Matco puller. Like one of the above posts said, it just reaches the back of the snout on the hub, I think maybe 3 inch reach. And I didnt have to put a lot of effort on it. Just tightened it up tight and hit it with a decent size ball pien hammer, and the drum/hub ***embly popped free. And yes I beat the **** out of it first before I did the research to find out its a taper fitted ***embly.
  26. 40FordGuy
    40FordGuy
    John Evans,...you definitely lucked out, bu using a stud attatched puller.... We did that also, bent a cpl of drums, as well as succeeding in removing others. That was in the late 50's,...when replacement drums were available everywhere.
    4TTRUK
  27. oldrelics
    oldrelics
    from Calgary
  28. TexasSpeed
    TexasSpeed
    from Texas
    Agreed! I spent hours and hours fighting a drum that had rusted to the brake linings and it wouldn't budge. JeffreyJames turned me onto this little gem so I bit the bullet and ordered one.
    Let's just say, my hammer is officially and definitely retired from all future "drum-bashing."
  29. AZ 54 BELAIR GUY
    AZ 54 BELAIR GUY
    from AZ
    I've had the center of the drum rust right to the axle before. Cleaned all the rust off the axle and I was able to get the drum off.
  30. InPrimer
    InPrimer
    A "trick" I learned a long time ago, there is no sense using a steel hammer to persuade something to come off, on the other hand I got a 8 lb Br*** hammer that fits the bill
