i need help identifing merc heads
Discussion in 'The Hokey Ass Message Board' started by dukes, Feb 19, 2008.
  1. dukes
    dukes
    from minnesota
    i have what i think to merc 410 heads. the casting numbers make no sense. they read, 6090E and RDC between the two center ports. where the date code is it reads 87K. i really need to know what they are off of.
    thanks Lucas
  2. 6090 is the FoMoCo nomenclature for a cylinder head (group number)....you'll find it on Y heads, FEs, six cylinder heads...etc. Doesn't mean anything other than that the part IS a cylinder head.
    Need a little more information. Did you check the underside of the heads?
  3. dukes
    dukes
    from minnesota
    i did check everywhere i listed all the numbers that are on the heads.
  4. 53 effie
    53 effie
    The RDC is likely actually EDC. If so, those are early FE heads, like 1958-1959 or so.
    Do they have a frost plug on the end?
  5. dukes
    dukes
    from minnesota
    there are no frost plugs on the heads
