I need help ID'ing this wheel
Discussion in 'The Hokey Ass Message Board' started by hudsoncustom, Dec 8, 2006.
  1. hudsoncustom
    hudsoncustom
    I found this wheel in a junk pike. I need to ID it so I know what to look for (I need 3 more).
    15" wheel, 5" wide.
    5 on 4.5" bolt pattern.
    Very shallow on the front side and lots of dish on the back side.
    I'm thinking it is 50's Chrysler product as it has the 5 spare holes with hubcap clips. The last photo shows the color best, it's a robin's egg blueish with 3 red pinstripes...
    Can anyone help with a positive ID?
  2. greyone
    greyone
    Looks just like the one on my 50 Plymouth.
  3. 40- 41 or 46- 48 dodge I think. Could be the same as 50 Plymouth?
  4. squirrel
    40s-50s mopar....could fit a lot of different cars.
  5. seymour
    seymour
    from PNW
    I would say '49-'54 Plymouth. I think the center changed slightly in '55
  6. Squablow
    Squablow
    I have a set from a '54 DeSoto which look identical. I'm going to tell you that any 49-54 Mopar product would have a wheel like this. The extra holes are for the locating pin for wheel bolts, and the hubcap clips probably indicate that these were on a cheaper model (Plymouth most likely) but I think the wheels are all the same.
  7. el Scotto
    el Scotto
    from Tracy, CA
    Yep, them's 49-54 Plymouth wheels. The 42?-48 earlier ones are 16" and look similar.
  8. hudsoncustom
    hudsoncustom
    Awesome. Thanks for the responses guys. If anyone has spares, I need at least 1, but I'd like 3.
    I'll put an ad in the cl***ifieds....
    thanks again...
  9. seymour
    seymour
    from PNW
    What's it going on? You might have better luck getting Ford wheels...
  10. wheelkid
    wheelkid
    Alliance Vendor
    from Fresno, CA
    Plymouth, but only if it's 4.5 wide. Have you have the tire off and measured how wide it is?
    Jimmy
