I need help on getting info on a 1958 Caddy 355 motor
Discussion in 'The Hokey Ass Message Board' started by dizzy66devil, Jan 9, 2009.
  1. dizzy66devil
    dizzy66devil
    I just received a 1958 caddy 355 motor and trans and I need help getting some gaskets and any other technical info on is such as the firing order etc please help thanks
  2. Caddy-O
    Caddy-O
    Firing order for your 365 is 1,8,4,3,6,5,7,2
    Timing is 5 deg deg. before top dead center.
  3. Rich Rogers
    Rich Rogers
    355 not 365 but the firing order is right. Left bank is 1357 and right is 2468
  4. hotrodj54
    hotrodj54
    in hemmings there is a guy who sell parts for caddy engines and he is very reasonable in orice his name is tyrell machine. ive used him before has lots of parts
  5. Caddy-O
    Caddy-O
    Not to split hairs but Cadillac used 365 series engines 1956-1958.
    As far as gasket kits go, you can order them at NAPA or O'reilly's.
  6. Rich Rogers
    Rich Rogers
  7. dizzy66devil
    dizzy66devil
    I was told it was a 355 so thats what I am going by. Is the electrical syster 6 or 12 volt I received the generator with the motor too. Does anyone know if you can convert it over if its a 6 volt one.I really dont want to have to make up brackets for a alternator, I would like to use it.
  8. Mr48chev
    12 V and 12 V generators should be available without a lot of hassle.
    Do a bit of hunting for factory shop manual for that year of Cad. It may cost you a few bucks but will be well worth it when you need detailed instructions on working on the engine. Also The Motor Manual for that year should be pretty good.
    That is what the independent shop mechanics used when working on that engine back when.
    http://www.factoryautomanuals.com/Motor-Auto-Repair-Manual-1949-1958-Domestic-p/59620.htm
    Link to the 58 Cad factory supplement. It looks like it is a supplement to the 57 Manual.
    http://cgi.ebay.com/ebaymotors/1958...emQQcategoryZ34212QQihZ027QQitemZ400018176826
  9. dizzy66devil
    dizzy66devil
    Anyone a good replacement regualtor to use
  10. Caddy-O
    Caddy-O
    Should be a 12 volt generator you have. I'm pretty sure Cadillac switched over to 12v in 56.
  11. cad and olds switched to 12 volt in 53
  12. RichFox
    RichFox
    Don't know but I don't remember any 355 Cads. 365 I remember.
  13. r8odecay
    r8odecay
    You were told wrong, is a 365. And yes, is 12V genny from 53' on. The tag on the case should say 12v on it as well. Autozone has the gaskets cheaper than any others i found online, but likely be special order anywhere you go. Plenty of caddy engine threads here chock full of info. Good luck.
  14. battersea boys
    battersea boys
    from surrey
  15. arkiehotrods
    arkiehotrods
    '49-'55 Cadillacs were 331.
    '56-'58 were 365
    '59-'63 were 390
    There aren't many engines that sound better than one of the early Caddy OHVs.
  16. r8odecay
    r8odecay
    so anyway, what intake manifold you got on that 365??
  17. Dale Fairfax
    Dale Fairfax
    And, just where did you search and what source did you find that told there was a 355" Cad?
  18. dizzy66devil
    dizzy66devil
    I was told by the buy the guy who gave me the motor it was a 355 he was so wrong.The intake is the stock cast iron one with a carter afb carb on it it would be nice to get a aftermarket one if I could find one.
  19. Do a search for the Cadillac thread by Cadillakin Marcus from a couple of years ago. It keeps popping up from time to time. It's got lots of good Cad info...
  20. krooser
    krooser
    The intake should be fine unless you want multiple carbs.
    the AFB is pretty much an Edelbrock so caould use the carb.
    It's a 365... trust me. I was there.
