Technical I need help to identify my flathead V-8
Discussion in 'Traditional Hot Rods' started by Retired, Jan 16, 2023.
  1. Retired
    Retired
    I know that on the 49 to 53 engines, there is a 3 or 4 digit set of letters and numbers on the back p***enger side of the intake manifold surface to tell when the engine was manufactured. ( at least that's what I've been told )
    Here is a photo of that area on my engine. There is a square with a 77 in it and the letter " R " ?
    Closer view.
    It has S 884 cast on the p***enger side of the bellhousing mount.
    I would appreciate it very much if someone could clear this up for me.
    Thanks .. Ray
  2. alchemy
    alchemy
    That's a wives' tale. Some states required a serial number stamped on the block too, but it was rare to be done to flatheads.
    But, the "R" does mean it's a "race" engine.
  3. Retired
    Retired
    I'm sure you're right about that. This was suppose to have been used in a dragster back in the late 50's and early 60's.
  4. Slopok
    Slopok
    More likely "refurbished" than "race"! :rolleyes:
  5. Fortunateson
    Fortunateson
    No, no, no! This is how the old “wives tales” come into being. The R simply paint the engine red! No other colour will give as much HP.....
  6. Retired
    Retired
    Don't know what I was thinking ... I actually thought someone here could help me out ?
    clem and ProtoTypeDesignFlauz like this.
  7. Budget36
    Budget36
    Chill a bit, guys are having some fun on your behalf. I’ve read there are ways to sorta figure out what era a Ford FH v8 was from, but there’s no way to tell the year/month/day, it was made.
    That said, all replies about “R” are so wrong.
    Everyone knows that “R” is for reverse. Geesh.
    '34 Ratrod, alanp561 and Retired like this.
  8. Retired
    Retired
    Thank you. That answers my question.
    Budget36 likes this.
  9. Budget36
    Budget36
    All good.
    What is the engine destined for? The fellas on the FordBarn may be able to help you with some info/advice, etc as well. Look at the EV8 section.
  10. Retired
    Retired
    Thank you. I'll check that out.
  11. alchemy
    alchemy
    Sorry I was trying to be cute. As they said, all blocks from 49 to 53 are pretty much the same, with no real way to tell what they came in. And it won’t make any difference. Only true difference that might make you want to change is the later valve seats were ground directly in the block. It’s common to cut and install new seat inserts.
    Retired likes this.
  12. Retired
    Retired
    No problem. Like I said, you may just be right about the " R ".
    I see on that chart that Rick Fisher posted that the letter " R " stands for the #9.
    do you suppose that the R on this block would mean it's a 1949 ?
    I was just trying to figure an actual year for and if it was a Ford or a Mercury it but not knowing that isn't a problem at all.
    Ray
  13. Fortunateson
    Fortunateson
    I was hoping you were going to put it in that GMC in your avatar!
    Retired likes this.
  14. oliver westlund
    oliver westlund
    If you google your question and add hamb at the end you will find hundreds of threads. Ive tried the search function in the site and find it less helpful than google
    Retired and clem like this.
  15. ydopen
    ydopen
    Retired likes this.
  16. Budget36
    Budget36
    I wonder if that’s all inclusive, or for some years? I’d think if every FH V8 had that done, there would be more knowledge about it?
    I don’t hunt out FH V8 info though.
    Retired likes this.
  17.
    Retired likes this.
  18. I agree
    Retired likes this.
  19. Atwater Mike
    Atwater Mike
  20. ronzmtrwrx
    ronzmtrwrx
    56B7AAB5-B73C-44B4-8B52-C650B558487B.jpeg Those sideways pics mess with me on my phone. :D
  21. Frames
    Frames
    Stupid question. It's an 8BA. Get a life.
