I need help with electrical problems with my 55 Chevy Belair.
Discussion in 'The Hokey Ass Message Board' started by evol55, Mar 20, 2011.
  1. evol55
    evol55
    My car will not start. I checked all the wires and they are not loose or frayed. We byp***ed the box on the outer fire wall and it started. We think the box is bad. Now I just need to know what that box is called to go and order it. I do not think it is a relay. I also checked the fuse box and all the fuses are not blown out. We checked the alternator, starter and battery also. They are good to go so please help me out. Thanks, Evol55.
  2. 40Standard
    40Standard
    from Indy
    not sure what box you are referring to. pics would help
  3. marc33
    marc33
    Ballast resistor? About 1"x3" white?
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Explain box a lil better, a pic would be better.
  5. 1971BB427
    1971BB427
    from Oregon
    If it's the ballast resistor you can jump around it and see if it fires, then replace it if that works. Don't permamnently jump it unless you've converted your distributor to electronic. Stock dist. need it to keep the points from frying.
  6. Engine man
    Engine man
    from Wisconsin
    If it isn't the ballast resistor, then it is an aftermarket system of some type.
    The original ballast resistor would be a ceramic hollow block with what looks like a spring inside.
  7. evol55
    evol55
    He is the box in question. Thanks for your help. This car has a 93 lt1, and HEI
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    that looks like a starter relay from a chrysler product??? I dont know why someone put that on there your car doesnt need it
  9. mrspeedyt
    mrspeedyt
    looks like it might be a horn relay. how did you 'byp***' the box??
  10. that's a confusing mess of wires , and i have no idea what that "box" is doing.
    what i would do is follow each wire that is attached to it to see where it goes. maybe with that info we could figure out what it is supposed to do
  11. Engine man
    Engine man
    from Wisconsin
    It sure looks like a Chrysler starter relay. Maybe it's connected to byp*** the ballast resistor for starting.
  12. 26 roadster
    26 roadster
    that is not 55-57 chevy? unaware of its purpose.
  13. Engine man
    Engine man
    from Wisconsin
    That master cylinder isn't stock either. Did a shoemaker own that car?
  14. squirrel
    Like they said, it's a Chrysler product starter relay. If you want us to help you figure it out, you're going to have to do some detective work, and also learn how to draw an electric schematic...even then it's going to be tough to figure it out over the internets. Suggest you find someone nearby who knows how electrons work, and get them to take a look at it. The wiring looks scary though....good luck
  15. pcterm2
    pcterm2
  16. tommy
    tommy
    From what I can see, I'd recommend rewiring the whole car. I do my own but for a novice you probably want a wiring kit. At least you will get instructions and a 1-800 number for help if you get into trouble.
  17. Dan57
    Dan57
    So, I think we need some more info. Does the car crank over?? What engine is in it? What type of ignition system?
  18. low budget
    low budget
    from Central Ky
  19. that sure as heck aint original to a chevy- thought you were talking about the voltage regulator.... but someone jerry rigged that ****er.... we got 8 trifives and aint 1 of em wired up like that... the location is for your ballast, but that aint a 55 chev ballast, maybe a chry start relay if it still has a generator on it
  20. Johnny Gee
    Johnny Gee
    from Downey, Ca
    As said many times already. It does not belong and the wiring is a rats nest. Needs a redue.
  21. stronga
    stronga
    I agree it does not belong. It looks like a relay of some type. I found one on my car that the previous owner put on as a failed attempt to keep the battery from running down. I took it off and put in a new wiring kit.
    Ps. The mystery item is where the resistor would go.
  22. evol55
    evol55
    Thanks for the answers. I have had this car for almost 9 years now and have always wanted to redo the original wiring. Over the past two years I have been unscrewing what has been screwed up by the guy I have got it off of. I think now is the time to do the wiring. I just replaced the worn 350 engine for a newer 350. Thanks, Evol55.
  23. evol55
    evol55
    Thanks for the answers. I have had this car for almost 9 years now and have always wanted to redo the original wiring. Over the past two years I have been unscrewing what has been screwed up by the guy I have got it off of. I think now is the time to do the wiring. I just replaced the worn 350 engine for a newer 350. I also replaced the front drum brakes with disc brakes and no that master cylinder is not stock. Not a former shoemakers car it was a trailer trash druggie that had it. Thanks, Evol55.
