I need more help.....soon
Discussion in 'The Hokey Ass Message Board' started by flatheadpete, Aug 4, 2006.
  1. flatheadpete
    flatheadpete
    from Burton, MI
    The Beater is runnin' bad again. I jumped in to go to work today and it won't even get to speed in the neighborhood. A few weeks ago, I put a post up about it. I ran it out of gas. New gas, ran like a champ....for a bit. New cap, rotor, coil, plugs, rebuilt (again) the carbs. Doing the same thing. Idles fine, free revs fine. Under a load, it falls....hard. I want to take it to HotRodToHell's party tomorrow. I would take me about 16 hrs to go the 10 miles at this rate. ANyone wanna come over and give me a b-day present in the form of gettin' my flathead runnin?
  2. blown49
    blown49
    Don't see the condenser metioned, could it be a bad Chineese one?
  3. flatheadpete
    flatheadpete
    from Burton, MI
    Pertronix....Offy heads and intake w/dual 94's. I need a friggin' vacuum gauge.
  4. bradley.w.lusink
    bradley.w.lusink
    this is an indication of either plugged main jets or low float level/low fuel supply. did you make sure the line from the tank to the pump flows freely? run it for a few minutes, shut it down and check the float level. make sure that you don't have any **** built-up behind the inlet valve(needle&seat) at the carb. when you rebuilt the carb did you blow-out the main p***ages AND the jets? disconnect the line from pump to carb, put it in a jar, crank it over for a few seconds and check pump output. one of these should uncover your problem. ....don't replace your ignition to fix a fuel problem
  5. flatheadpete
    flatheadpete
    from Burton, MI
    Did that...still ****py. New filters, blew out all the lines, double checked the fuel pressure. I'm gettin frustrated......I've got a small block Chevy that'll make 3x the power....maybe I should.
  6. Thirdyfivepickup
    Thirdyfivepickup
    this is not the way to be spendin your birthday. You should be gettin 31 GMB spankins.
    (no help with the flatty, just wanted to mention the birthday spankins) :)
    Good luck, young Pete.
  7. I got 3 important words for you:D [two] times......
    TWO-many-carbs
    CHANGE -THE- PLUGS.
    [GOOD LUCK PETE]:)
  8. flatheadpete
    flatheadpete
    from Burton, MI
    More words......big cam. Been runnin' great for 3 yrs. Also....in my first post, it states NEW PLUGS.
  9. jdubbya
    jdubbya
    Bill Wallace.... he is your man!
  10. tommy
    tommy
    Is the Pertronix in a stock Ford 8BA dizzy? Refer to Bruce's marine floatation test in the archives.
  11. Flatman
    Flatman
    Hey Pete,
    No need to ask how it's going, eh? What do your plugs look like? Any signs of arcing around the rim?
    Flatman
  12. flatheadpete
    flatheadpete
    from Burton, MI
    Pertronix in a stocker dizzy....plugs indicate lean mixture. Running .045 jets and 3.5 power valves. Up til the last '****py running episode' I ran .041 jets and 3.5 power valves. Frustrating as hell. I'm gonna give Bill Wallace a call and see if I can limp it out to his house. Hope it doesn't overheat at 20-30 mph.
  13. fab32
    fab32
    Have you even thought about having Frankie take a look at it? last time I saw her she looked like she could solve a little problem like this. Now, world peace or a better mouse trap might take her awhile.:eek: :D
    If she can't figure it out at least tell her that Frank in Bay City misses her and give her a hug for me.:)
    Frank
  14. Flatdog
    Flatdog
    Pete, try this take off air cleaner and look down carb wile slowly opening it up.See if gas is being ****ed up through venturie .race motor up and choke it with your hand.What happeneds is some dirt clodded main jet,chokeing it by hand will sometimes **** it through.Runing out of gas is the tip off,you ****ed up dirt from the bottom of the tank.
  15. Flatdog
    Flatdog
    PS Pete stop that chevy talk please.
  16. Sooorrrry mr touchy-just tryin to help ya....
    I have seen new plugs that have been gas fouled fairly quick-especially on a small inch motor with two carbs or more.....
    I suppose you will figure it out.
  17. Flatman
    Flatman
    Have you flushed out the fuel line? Any places where there are neoprene hose that might be collapsing under load? Are you still running the same electric fuel pump? Have you checked the flow of it off the car?
    Flatman
  18. flatheadpete
    flatheadpete
    from Burton, MI
    My goofy 2 yr. old kid was makin' goofy noises at dinner tonite. It made me think..."Better check for vacuum leaks one more time." I busted out the carb cleaner. Started it up and sprayed the bas of front carb......good. Sprayed the base of #2......stumble. Apparently, the front bolt (ya know, the upside-down one) has been over-tightened, stripping the threads. Kritz has another main carb body I can swap on to check this theory out. I'll do that tomorrow morn....I'm beat.
    Frank, I should take Frankie's advice more often. I mean, what else could "Tttsssssssssssssssssssssss" mean but, "Hey dad, your car makes this sound!"
  19. Thirdyfivepickup
    Thirdyfivepickup
    that Frankie is a genius!
    (must get that from Mom, huh?) :)
