I need my block fixed
Discussion in 'Traditional Customs' started by jfrausto, Jun 23, 2014.
  1. jfrausto
    jfrausto
    I live in Los Angeles I have a crack in my block I've have the block with my mechanic he tuck it to a machine shops and they don't want to fix it I've came across a video on you tube that it's is fixable my mechanic is telling me I need a new block I need to take it were they fix this problem ImageUploadedByH.A.M.B.1403564761.436539.jpg
  2. jfrausto
    jfrausto
    It's a flathead
  3. BOBCRMAN
    BOBCRMAN
    from Holly
    Easy cold fix. A piece of tube or old valve guide and a
    heli-coil. Maybe a couple of Lock-n-s***ch across the crack
    Find a thin wall sleeve and a lock-n-s***ch. S***ch the crack. Drill hole, apply seal and press in the sleve. Then Heli the rest. Mill flat
  4. RichFox
    RichFox
    look up H & H flatheads 4451 Ramsdell Avenue
    La Cresenta, CA 91214. Bet they can fix it.
  5. rjaustin421
    rjaustin421
    That appears to be highly repairable with s***ching (one brand name as previously mentioned is Lock-N S***ch. I have repaired much worse than that even cracks that traveled across the seat which required a valve seat insert.
    No way is that block a boat anchor.
  6. I agree with these guys. I zoomed in on the picture. Worth fixing. Don't junk it.
  7. alchemy
    alchemy
    The cracks seem to go north of the stud hole and south of the water hole. Hard to see with the eye, but you sure need to see how far they go before you throw lots of money at it. If they creep into the bore it might need a sleeve.
  8. Does your mechanic or the machine shop he took it to work on many flatheads? If not that may be part of the problem. If a late block looked like that it might be time to replace it but I would get the opinion of someone that works on flatheads. The only shop I know of is Kelly's Block Welding in Culver City, (310) 827-6795. They look like an old time shop and seem they have been there forever. You might check some places they work on diesel engines for a recommendation on crack repair. You might want to start a thread ***led "Block repair in Los Angeles".
    Charlie Stephens
  9. Mike51Merc
    Mike51Merc
    Just about every flathead has a crack in that location. Most don't need any repair at all.
  10. Yep some of them guys think that they are like small blocks and just laying around waiting for someone to build 'em.
    H&H has been mentioned and that is where I would go if I were on the coast. I have repaired a block or two in my time and some that I was proud of. I would still take it to them if it were mine.
  11. jfrausto
    jfrausto
    ImageUploadedByH.A.M.B.1403635800.648840.jpg ImageUploadedByH.A.M.B.1403635822.255395.jpg ImageUploadedByH.A.M.B.1403635842.439699.jpg ImageUploadedByH.A.M.B.1403635867.984386.jpg ImageUploadedByH.A.M.B.1403635884.374766.jpg ImageUploadedByH.A.M.B.1403635912.883722.jpg ImageUploadedByH.A.M.B.1403635927.881977.jpg
  12. jfrausto
    jfrausto
  13. jfrausto
    jfrausto
    I found this shop yesterday I talked to him he said he could fix it, the mechanic said he was going to give him a call today will see
