i need schooled on torching
Discussion in 'The Hokey Ass Message Board' started by oldnuts, Mar 19, 2013.
  1. chopo
    chopo
    sounds ***** hot..... gotta ask the wife.:)
  2. oldnuts
    oldnuts
    from nebraska
    I tried to heat the bolt but there wasn't much left of it that wasn't mushroomed and cut off it was just about even with the top of the wishbone. Ill do some measuring and post what I find out. That splatter literally happened within seconds of when I started to heat it.
  3. oldnuts
    oldnuts
    from nebraska
    ImageUploadedByTJJ1363826309.370062.jpg look like I was doing something wrong?
  4. tooljunkie
    tooljunkie
    from manitoba
    my methods are a little different,heat to a low glow,before it gets red and pour
    water on the bolt.too hot and you change the temper.
    reheat it til the water boils out and cool it again
    three or four times before getting aggressive with the swinging press.
    another is the air hammer and hot water.whilst pouring hot water on the joint i rattle with air hammer.rust turns to brown mud.unlocked many things without torches.
  5. homemadehotrod
    homemadehotrod
    i think it will be fine. just fill the place where it dripped out with weld and buff it smooth
  6. xix32
    xix32
    best tip i've read about getting those out, is to pull them out - not push them out.
    if you heat the perch it expands, then if you try to push it out while it's hot ( expanded) that just swells out the perch and makes it even harder to get out.
    the solution: build a puller, put some tension on the perch while heating ( expanding) the axle.
  7. oldnuts
    oldnuts
    from nebraska
    I'm gonna clean and then magnaflux the axle then research how to use filler rods then attempt to fix my mess up. Thanks for everything guys
