1952-59 Ford I need some help with my horn ring
Discussion in 'Off Topic Hot Rods & Customs' started by HOTRODPRIMER, Mar 9, 2012.
  1. HOTRODPRIMER
    HOTRODPRIMER
    OK,I can get my horn to work by placing a screw driver across the wire that comes through the steering shaft,,but I must be missing something on the back side of my horn ring,,I can get my horn to work by placing a screw driver across the wire that runs up through the steering shaft, because when the wheel is mounted and the ring is pressed,,NOTHING
    Anyone have a exploded view of a horn ring or can you take a photo of yours removed from the wheel that shows the back side? HRP
  2. rld14
    rld14
    Danny,
    Maybe the height of the contact? Is it sticking?
    Best I can do is scan pages from the factory manual on Monday if it's any help
  3. streetdreams
    streetdreams
    You have a small socket like piece at the end of the wire with a springy ****on on the end that fits into the end of the steering shaft, correct?
  4. HOTRODPRIMER
    HOTRODPRIMER
    Yes,the spring and ball are in the steering shaft.
  5. streetdreams
    streetdreams
    Then you've got a problem with the horn ring. When it installs, there is a spring under it, holding it away from the steering wheel, but touching the spring/ball socket. When you depress the ring, contact is then made to ground through the spring/ball, activating the horn. If the horn doesn't work, there's a problem under the ring.
