I need some help with tire size!
Discussion in 'The Hokey Ass Message Board' started by jmill83, Feb 16, 2010.
  1. jmill83
    jmill83
    Hey guys heres my question: Im wanted to run oem style chrome rims on my 52' F1 with bias plys, what size tire should i go with? I plan on lowering the truck with a 3" drop axle and probably remove a few springs up front to lower it around 5 or so inches and around the same in the rear. I was also thinking maybe a little bit taller tire in the rear. Thanks for all your help guys.
  2. jmill83
    jmill83
  3. Hnstray
    Hnstray
    from Quincy, IL
    If by OEM style you mean steel wheels that are a bit narrow like the originals, probably on front a 6.70-15 would be appropriate.....rear, if you want a bit taller, 7.10-15.....both these sixes were OEM sizes on lighter cars (Ford,Chev,Ply, Merc) of the period.
    Ray
  4. brandon
    brandon
    depending on wheel diameter..... atleast a 8.20 / 15 rear or 7.50 / 16 rear....fronts , depending on how low.... 5.60/15 or 5.00/16 ride height would probably make the dictate the tire to me. and you gotta have some hot rod rake..:D
  5. wvenfield
    wvenfield
    Go to Coker Tire and input your vehicle and they will list the original equipment size.
    From there you can picture a little larger or smaller.
  6. jmill83
    jmill83
    Thanks for your input guys, im wanting to run 15's and as for coker i could just be over looking it but i tried to imput my truck but it wasnt an option under the ford drop down.
  7. theorangecouch
    theorangecouch
    Yo Bro, This is what I've got, a 3" Drop Axle and 3" blocks in the rear. Got it all from Sids @www.droppedaxles.com I removed 3 leafs from each corner. She's sittin on 640-15 with 2 1/8" w/w, firestone bias ply tires. Good luck!
