Hot Rods I need to borrow a fire suit
Discussion in 'The Hokey Ass Message Board' started by Bob K, Jul 22, 2011.
  1. Bob K
    Bob K
    from Antigo Wi.
    Anybody got one I can borrow for B'ville. I have an opportunity to drive on the Salt this year but need a current Fire Suit.
    It needs to fit a short fat guy.
    5'7" tall
    201 lbs
    38 " waist
    44 " chest
    27 " inseam (Yeah I know I'm short AND fat)
    B:DB
  2. I will add it should be an SFI 15 or 20
    Did you post on landracing.com Bob?
  3. Mrs. Clause won't knit you one?
  4. Bob K
    Bob K
    from Antigo Wi.
    Yes but it wouldn't pass inspection.
    B:rolleyes:B
  5. Russco
    Russco
    from Central IL
    Bob I have 2 old suits here. They are both SFI 3-2A/5 certified but they are from my skinnier days I know they would be a bit long for ya and maybe to small in the torso but if you cant come up with anything else you are welcome to try one or both of them to see if they will work Let me know. Mike
  6. I'll look at mine, same as required for drag racing?
  7. Needs to be a 15 or preferable 20 as I stated above. Anything else is just a costume:p
  8. Russco
    Russco
    from Central IL
    Oops Gotcha, well thats that
  9. Mr48chev
    Out of this years Rule book
    Make sure that everything you intend to use fits the class you intend to run it.
  10. Also you need to wear the spec for the RECORD in your class, even if your car runs well under those limits. Also remeber you may be 1 mile or 3 miles away from the closest safety crew. From what the vets have been telling me, and I am still learning, there is no such thing as overkill when it comes to fire protection. The general consensus if you ask is nothing less than a 20 cert. There are some good discussions over at landracing.com if someone wants to learn.
  11. RichFox
    RichFox
    Don't forget you need a Hans device also
  12. ^^^^^^^^^^^^^^^this is one of those vets we need to listen to!
  13. uncle max
    uncle max
    Just like me... Used to wear bellbottoms, now I wear belltops.
