Technical I need to know about blind screwing
Discussion in 'The Hokey Ass Message Board' started by williebill, Jul 29, 2020.
  1. williebill
    williebill
    Tried to think of a catchy ***le. Here's my situation. 6" long 3/8" bolts need to be threaded deep into this thing with no access to the back, and no way to see what and where I'm doing..
    I'm building my own version of cage nuts to be welded inside, using 1' deep nuts. I can get to everything while welding it up, but not when ***embling it for the last time.
    I can trial run it as many times as I need, but Murphy's Law and the possible movement during some of the welding may complicate stuff.
    So the simple question is should I grind down a few threads on the 6" bolts to make them easier to start into the nuts, and if so, how? Just take the top off of the threads ? Would think 3 or 4 threads would be enough, and that number would p*** through the 1" nuts, so they don't have to hold any torque.
    Sorry, no pics, don't think they could help or show what I'm doing very well. TIA.
  2. K13
    K13
    nunattax, Hnstray and williebill like this.
  3. usually tapering just a couple threads SLIGHTLY is all you need to get them started
    VANDENPLAS, williebill and wraymen like this.
  4. 56don
    56don
    Can you weld a thick piece of metal behind instead of cage nuts? Then you can drill and tap a hole afterwards.
    But give me more info about blind screwing in case I lose my eyesight..:(
  5. wheeldog57
    wheeldog57
    What Tman said^^. First couple of threads only and file the slopes of the threads, good luck
    williebill likes this.
  6. hotrodjack33
    hotrodjack33
    Yeah, I do that all the time. I'll take a bolt and run a nut all the way up. Then on the belt sander, roll it in my fingers at about a 45 degree angle...it gets hot...and it doesn't have to be all that accurate. I usually grind it until I can no longer see the first full thread. Take it over to the wire wheel to clean it up and then run the nut back down to re-align any of the ground threads. Works every time.:)
  7. 2OLD2FAST
    2OLD2FAST
    from illinois
    Dependent upon what you're screwing , you may be better off blind !
  8. 56don
    56don
    Been there....done that....
  9. 210superair
    210superair
    from Michigan
    Just clicked on the thread for the first joke. Not disappointed.
    King ford and williebill like this.
  10. squirrel
    This stud is made to be able to put a nut on quickly, without having to take time to line it up. As in pit stop roundy round tire change quick. It's been developed and refined over decades.
    Dino 64, jimmy six, alanp561 and 3 others like this.
  11. williebill
    williebill
    Thanks to everyone for your help. Good tips.
  12. 41rodderz
    41rodderz
    from Oregon
    Well at first I was going to tell him just to close his eyes.:p
  13. rudestude
    rudestude
    SIREN!!!! Wow Wow Wut Mr. Police Man....
    With wuts going on in the news lately and then throw some political stuff in there , which is not allowed on the H.A.M.B anyways....do I smell a dirty cop?
    hahahuh...
    Sent from my SM-T387V using The H.A.M.B. mobile app
    jimmy six likes this.
  14. The37Kid
    The37Kid
    I don't have a good picture of what you plan to do. Be sure you finish with a bottoming tap so the studs don't seize. Bob
  15. lurker mick
    lurker mick
    Yeah, ol Darin is a real comedian. HAHA.
    Mick
  16. Fordors
    Fordors
    Likewise. If you could provide a sketch maybe someone will have a helpful idea.
  17. Hnstray
    Hnstray
    from Quincy, IL
    @squirrel has it right.
    IMO, tapering the threads increases the likelihood of cross threading the bolts not decreasing. Whereas, the parallel reduced diameter tip of the bolt insures the ‘piloted’ bolt is axially concentric with the ‘nut’ threads.
    Ray
    williebill, alanp561 and Moriarity like this.
  18. tb33anda3rd
    tb33anda3rd
    is the hole sloppy? yeah, yeah, seriously either the nut or the long bolt have to have some movement to align with out cross threading. can you use a long stud and an acorn nut?
    The37Kid, Hnstray and williebill like this.
  19. williebill
    williebill
    Thanks again for everyone's ideas. Much appreciated. Won't need a bottoming tap, the long bolts p*** through the 1" deep nuts. My concern isn't the nuts down on the inside, but guiding, and screwing everything together blindly, after I weld the pieces together, and possibly warping **** just enough to cause problems. TB33, if I could use studs, I would. Can't make that work in my convoluted, overkill, "Rainman" world. If I did **** the easy, proper, reasonable way, my project would already be on the road.
    I've finally gotten used to doing stuff the hard, stupid way, can't seem to help it. Sometimes it even works out OK.
    Thanks, folks ! I've got more ideas now .
  20. 41rodderz
    41rodderz
    from Oregon
    Are you going to use my idea .:D
  21. williebill
    williebill
    Sure, what could go wrong? Can't hurt.
    hotrodjack33 likes this.
  22. Fortunateson
    Fortunateson
    Keep it simple...just turn off the lights!
    williebill and hotrodjack33 like this.
  23. Hnstray
    Hnstray
    from Quincy, IL
    Regarding turning off the lights......it’s not only the men who may make that call.....:D
    There is an old saying......”In the dark, all cats are grey”.....;)
    Ray
  24. hotrodjack33
    hotrodjack33
    ...and all women are beautiful...;)
  25. GTS225
    GTS225
    Can you use a couple temporary studs to get things aligned and loosely ***embled, then screw in your bolts, remove the temporary studs, and install the last couple bolts?
    Roger
    williebill and Hnstray like this.
  26. williebill
    williebill
    Thanks Roger, but no, there isn't anywhere to use temporary studs in the bottom.
  27. Fortunateson
    Fortunateson
    Yep, works for both parties! Now someone explain the purpose of a "temporary stud?".
    alanp561, williebill and DIYGUY like this.
  28. Hnstray
    Hnstray
    from Quincy, IL
    when the usual stud is either unavailable or out of commission??!! :D
  29. King ford
    King ford
    from 08302
    Screwing blind, studs, do it in the dark....nobody mentioned ALCOHOL here yet!....seriously, Squirrel as always is right on target. Many factory fender and hood etc. bolts have the first 1/4 to 3/8ths of the bolt diameter the same as the ID the clip nut, J nut , captured drilled and tapped bar etc.
  30. King ford
    King ford
    from 08302
    Ok, I can't resist!...I never went to bed with an ugly captured thing to screw into but I did wake up with one or two....
