Technical I think I know the answer
Discussion in 'Traditional Hot Rods' started by jerryt, Feb 4, 2023.
  1. jerryt
    jerryt
    I have on my truck the battery sits u dee the p***enger seat. I want to keep it there. But if I break down the seats are in the way. And I don’t like putting a metal sheet over the battery. It’s a safety thing. But can mount it in the bed but then it’s in the open. Any suggestions?
    Thanks
    Jerry
  2. twenty8
    twenty8
    Looks like you may have battery operated brakes ???.......o_O
  3. lippy
    lippy
    from Ks
    From the pics I'm not seeing what your saying. Lippy
  4. jimpopper
    jimpopper
    Well a short answer would be to use a Battery Box such as they sell for holding a boat's battery to protect it and fasten it in the bed.
    mad mikey and lothiandon1940 like this.
  5. jerryt
    jerryt
    Yes I agree barter box is simple way to go. I just don’t like my battery exposed. Thanks I kept bumping this in my brain. thanks
    Jerry
  6. ActionYobbo
    ActionYobbo
    do like a modern cars with a remote battery. Run a set of cables to a place outside the cab like under the hood or at the rear bumper area. mount them to isolated lugs and then you have a remote jump point. there are several modern vehicles with the battery hidden away in a hard to get to place and they all have jumpstart terminals under the hood
  7. pprather
    pprather
    I had a battery under the floor for many years. The sheet metal cover was made large enough that it wouldn't fall into the battery hole.
    Pist-n-Broke and VANDENPLAS like this.
  8. idiot
    idiot
    i fought with this for a minute.
    tryin to find the answer.
    i ended up putting my batteries under my bed in a sealed box.
    im going to make some leads and mount this somewhere hidden.
    another connector like it connects to it with jumper cables on the other side
  9. goldmountain
    goldmountain
    Get a smaller battery that will take up less space. My car has a lawn tractor battery. You don't need a whole bunch of cold cranking amps for an occasional nice weather cruiser.
  10. 56don
    56don
    I have one of the small dry cell batteries under the seat of my truck. It mounts flat on its side with the terminals on the side. You can see how I mounted it here:
    Just Gary, ramblin dan and hrm2k like this.
  11. stuart in mn
    stuart in mn
    It's not clear to me what your concern is...I ***ume by break down you mean dead battery? If so, I don't know why having to lift up the seat to hook up your jumper cables is that big a deal. Otherwise, you can install remote terminals under the hood or somewhere else handy.
  12. gimpyshotrods
    gimpyshotrods
    Remote jumper terminals: $21.99.
    https://www.summitracing.com/parts/sum-g1430
  13. footbrake
    footbrake
    Just put a piece of rug over the battery, problem solved.
  14. theHIGHLANDER
    theHIGHLANDER
    Who's in charge of this decision? Are you positive a negative result will occur? It's possible this topic can be a generator of alternate ideas. You just have to be grounded and an open mind to get ideas for your current situation. Members get amped up when it comes to certain things and it can be tough to cut out thru the field like old regulators. Still, you should be able to reach a terminal solution.
    That was good !:D
    But back to the issue at hand .
    I would mount the battery hidden in a battery box with terminals exposed somewhere to ***ist in boosting the truck .
    lots of different options .
    Putting it in the bed is fine as well a battery really does not care if it’s exposed. It would be more of a looks thing or taking up space in the bed then detrimental to the battery .
    mad mikey likes this.
  16. BamaMav
    BamaMav
    from Berry, AL
    Batteries have been put under the floors of vehicles for years, probably since they first started putting them in to run things like ignition, lights, and a starter instead of relying on just magneto for the ignition. As long as it’s in a secure place I don’t have a problem with it. Our new to us Jeep Grand Cherokee has it’s battery under the p***enger seat under the floor, with jump off lugs under the hood. Pa in law had a Caddy a few years ago with the battery under the back seat. Only problem I see would be in the event of an electrical fire and you needed to disconnect the battery real fast, but you can put an shut off switch in the cables to do that if needed.
    There’s worse decisions in life than putting the battery below the floor, like **** hanging below the scrub line, but that’s another discussion….
    VANDENPLAS and mad mikey like this.
  17. mad mikey
    mad mikey
    Take the advise you have been given. Battery placement is not rocket science.
  18. Johnny Gee
    Johnny Gee
    from Downey, Ca
    The polarizing look she made when her favorite toy didn’t work because the batteries were placed incorrectly.
  19. Sometimes I think these kinds of questions are posted just to build a larger post count. Come to think about it, that's the only reason I post on them!
    Budget36 and winduptoy like this.
  20. This ^^^ is more than doable. I had the battery inside a large print setters box in the bed of my C10. It was not visible to the general public and I could lock the box (it also held my jack and various tools). Where I live a battery out in the open is fair game.
    You can put the battery under the bed, I have done that in several trucks. You build a battery box off the side of the frame and a trap door in the bed.
    All that said the GIMP has the simple answer.
    Desoto291Hemi likes this.
  21. mitch 36
    mitch 36
    Both my 36 Chevy and my old 36 Ford have the battery under the floor on the p***enger side, never had an issue. Several times I've had to jump the Chevy because of a depleated charge, just hooked the cables or charger to the alternator lug and ground. Fired right up, no issue. Put it under the floor with a removeable panel and fuggetabou***.
    firstinsteele likes this.
  22. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Jump from the back of the alternator!?
  23. That works. I have put the cables on the lug on the starter before. Not easy on everything we drive but the alternator or the genny is normally right out in the open. Good idea.
  24. gimpyshotrods
    gimpyshotrods
    I would not, except to open the doors on a car with shaved handles.
  25. Bearing Burner
    Bearing Burner
    from W. MA
    I had a friend who was charging the battery under the p***engers seat,in his BuickThis was in a garage under his house. Seat fell down across battery and nearly burnt the house down. Use a plastic battery
    box with cover.
  26. pprather
    pprather
    Yes, I would not pull starter current through the alternator wire, unless it looks like a battery cable.
    gimpyshotrods and Pist-n-Broke like this.
  27. BJR
    BJR
    Just plain AWESOME!!!
    firstinsteele and theHIGHLANDER like this.
  28. Wouldn't this be the equivalent of a 10 gauge jumper cable? I agree and wouldn't go there.
    gimpyshotrods likes this.
  29. badshifter
    badshifter
    Remove the battery altogether and just push start it.
    You’re welcome.
    twenty8 likes this.
  30. '29 Gizmo
    '29 Gizmo
    from UK
    Modern batteries are maintenence free. So put them where ever you like. I have used anderson connectors to plug in a remote battery if i need to jump start.
