i think im gonna put 18s on my hot rod.
Discussion in 'The Hokey Ass Message Board' started by jeff, Jun 14, 2004.
  1. jeff
    jeff
    are those early 30's 17 or 18" spokes stronge enought to drive on or what? and how wide are they? i really like the way they look and i have a lead on some for cheap. thanks -jeff
  2. burger
    burger
    Jeff-
    I don't think so. '35 16" wire wheels wont hold up to a stout motor, so I doubt earlier rims would do any better.
    Ed
  3. Foul
    Foul
    jeez. COEs from the '40s had solid 20" wheels. so what if they were 2-part rims, you need to look for some of those. KEWL!!
    dan
  4. Deuce Rails
    Deuce Rails
    I agree with you, Jeff, they do look great. Run them if you can.
    Do you have the 5 by 5-1/2" lug pattern you need for them?
    What kind of engine are you using? I think that they're stromg enough if you're not making too much torque.
    I believe that they're all 5.5" wide, but I could be wrong.
    --Matt
  5. loudpedal
    loudpedal
    from SLC Utah
  6. flatheadpete
    flatheadpete
    from Burton, MI
    I run 18 inch Astro van spare saver wheels with F-stone bias plies on the rear of my bucket. They look correct and I didn't have to pay for 'em.!
  7. Bruce Lancaster
    Bruce Lancaster
    Ford welded wires are reasonably strong, but eyeball them very carefully--I have seen some that had a spoke or two with a dubious looking weld. If you're going to beat on them, try to select a set whose welds all look solid and without any deep pits in spokes--I have a feeling that one spoke failing in a hard corner could lead to a domino chain failure. I just got a perfect set from an olde Model A Geezer--those guys all bought themselves a set back before salt was invented, and then stashed them in storage when they went for restoration. Most of the ones at swap meets around here are horribly pitted junkers that sat out on an abandoned farm trailer for thirty years.
  8. Bruce Lancaster
    Bruce Lancaster
    An odd historical factoid: 18's, wires, high clearance solids, and Halibrands, were somewhat popular on fast Bonneville and Lakes cars because the Indy roadsters of the day had 18's, and those were perhaps the most available tires capable of really high speeds.
  9. NealinCA
    NealinCA
    I am looking for a pair of 18" bent spoke Kelseys with 5 on 5-1/2 pattern...for my next project[​IMG]
    Neal
  10. burger
    burger
    Pete,
    What year range of S-10's and Astros do you pirate the rear tires from?
    Thanks,
    Ed
