Projects I want some new body shop inventions !!!
Discussion in 'The Hokey Ass Message Board' started by 31Vicky with a hemi, Dec 21, 2017.
  1. Ok so I know how it goes, want in one hand and ,,,,
    But it would be nice if :
    A Body filler that you can slick down and form and get it all perfect perfect then spray the hardener on it and it sets. It should Work Just like the clay modeling guys stuff then kick off after its sprayed.
    We do the same **** as this guys but with sand paper that wears out on hard materials - the difference is this guy says it's fun and he never gets tired of it. His shaping tools are probably decades old.
    How about sanding sticks that look like a pencil and that you can use like a pencil eraser to sand with. Get all those details and various grits too.
    How about wet sand stones, like a hone stone instead of paper, for flat and low crown panels.
    While I'm at it, how about paint that repels dirt and bugs instead of attracts dirt and bugs.
    Do you want to know if a place is surgically clean? Just paint something and the wet paint will try to tractor beam dirt in from the moon. If that paint invention actually happens just skip the wet sand stones:).
    Asking too much ? I told Santa
  2. K13
    K13
    I will work fine if you only want to outer surface of your filler to harden. How much working time do you need? Evercoat makes a filler that at 75 degrees has 40 minutes of working time 80 minutes at 60 degrees.
  3. BJR
    BJR
    I want self leveling runs.:D
  4. painkiller
    painkiller
  5. gimpyshotrods
    gimpyshotrods
    I want enough money to farm out all of my bodywork.
  6. HOTRODPRIMER
    HOTRODPRIMER
    I want a pet monkey that can do the work for me! :D HRP
  7. I want a transporter badge so Scotty can beam me up. :cool:
    But this "modeling then hardening later" stuff might not be that far out. They already have resins that can be molded and then hardened with UV light. (My dentist uses it all the time.)
  8. If yer gonna wish, wish big!
  9. Oh no, it's got to harden all the way thru. Even if you had to bake it:)
    It's also the getting it slick and perfect perfect part.
    loudbang and henryj1951 like this.
  10.
    Mikel50, Gurt74, Timvmax1985 and 7 others like this.
  11. ceege
    ceege
    from NW MT
    That only works on the paint side. DOH!!:p
  12. K13
    K13
    Obviously but a spray on hardener would never be able to accomplish that with any consistency of cure.
  13. ceege
    ceege
    from NW MT
    Maybe something that cures with humidity like windshield urethane.
  14. K13
    K13
    Believe me this stuff is researched endlessly and the bottom line is market research shows that the vast majority of end users have very little appe***e for changing the way body fillers work so radical changes are unlikely.
  15. ceege
    ceege
    from NW MT
    Only one thing worse than sanding rock hard plastic filler and that is having to dig it out because it didn't get hard enough.
    reagen, catdad49, loudbang and 2 others like this.
  16. That's why it's a new invention ,
    And you better not tell Santa about your market research.
    I don't care how they do it, but they should.
    In this world I'm supposed to believe the sent men to the moon and I'm also to believe they can't "accomplish a consistency of cure" ? Well one of those is BS
  17. Yeah that kinda ****s
    Pinstriper40 and henryj1951 like this.
  18. pitman
    pitman
    Ahh, the old loop of masking tape calls !
  19. ceege
    ceege
    from NW MT
    I have had limited success in coaxing the run on to the floor.
  20. RMR&C
    RMR&C
    from NW Montana
    I want wet/dry sandpaper with sticky back for a long board
    timwhit, loudbang, henryj1951 and 3 others like this.
  21. K13
    K13
    It's out there but I can't remember who it was I saw it made by.
    loudbang, henryj1951 and RMR&C like this.
  22. Eastwood has that. It's from the line of soft sanders but you can stick it on anything. Up thru 2500 grit
    It's not cheap, when it's wet the sticky gives up before the paper is done. I've let it dry and sprayed it with some glue from the craft store and re stuck it.
  23. tb33anda3rd
    tb33anda3rd
    how about a filler sanding machine that you can program? example: program to 1934 ford 3w driver door, roll it up to the side of the car, attach to known points, as indicated by computer screen, on edge of door. set laser pointer, push scan, insert bondo cartridge, push go. note time of completion and move to a second machine on the other side of car. the machine then sprays the mixed filler in the low spots, then applies heat when complete a set of router bits machine the slightly high filler while a vacuum ****s the dust away. bell rings when done, at which point you have the second one running and refreshed your coffee. repeat with the next body part. then the booth.
    one body guy and two machines can complete multiple "hits" a day.
    clem, catdad49, loudbang and 5 others like this.
  24. pitman
    pitman
    or perhaps a Particle Filter w/a hint of laquer thinner ambrosia scent! :)
  25. Yeah like a roomba
  26. pitman
    pitman
    Hey! Time for the Legendary Cad-Lasalle to offer a few tips!
    loudbang, henryj1951 and ABONES like this.
  27. Now, now, now....what is all this about filler this and filler that? Why bother, just ask Santa for self-healing dents.
    catdad49, loudbang and henryj1951 like this.
  28. pitman
    pitman
    Dry ice... and a heat gun :p
  29. Johnny Gee
    Johnny Gee
    from Downey, Ca
    It would be a shame to let all that hand work of getting just the right angle and shape that's so desired just go to waste. [​IMG]
    henryj1951 likes this.
  30. Flathead Dave
    Flathead Dave
    from So. Cal.
    I want a blow up doll that doesn't pop....
    49ratfink, loudbang and henryj1951 like this.
