Technical I want to “pour” a hammer form, how ? What?
Discussion in 'The Hokey Ass Message Board' started by 31Vicky with a hemi, Jun 16, 2023.
  1. I’ve got a good quarter panel (rare and expensive) and I need to make copies of it. Lots of copies.
    I’m thinking if I flip it over, fill it up , and pop off the good quarter panel I’ll have a good mold to panel beat more. It’s got to be strong and hammer resistant.
    Thought about vacuum forming a copy too
    Idk what my best options or products would be for longevity.
    The overall weight isn’t a big issue as long as it’s under #1000 lbs. I’d like to keep the budget under couple thousand.
    Appreciate any leads to info
    Thanks.
    ElmCityGeoff likes this.
  2. HOTRODPRIMER
    HOTRODPRIMER
    Is fibergl*** out of the question? HRP
  3. In_The_Pink
    In_The_Pink
    Can you post a pic of the panel in question, please?
  4. It’s not, but I don’t think FG would hold up to the hammering or flow forming as a backup.
  5. 57 Fargo
    57 Fargo
    I think the concern with fibergl*** would be wanting to use it as a hammer form.
    caprockfabshop likes this.
  6. Sorry that’s cl***ified,
    Nominal, firstinsteele and Johnny Gee like this.
  7. I’ve recently heard about “polymorp” and similar products mostly for crafts. Anyone play with that?
    Thought about a 3d scan and print but it’s BIG
    Then irrc SAR made some molds out of some goofy material too. What was that?
  8. Happydaze
    Happydaze
    Iirc there is some pourable metal based material suitable for pressing panels but it has a fairly modest lifespan, unlike proper dies. This stuff sounds exactly what 32v is looking for, but can I remember what it's called or where I've heard it being used? Can I heck! Will ponder, but at least there's some confirmation that it's doable.
    Chris
  9. oldolds
    oldolds
    Make a fiber cl*** mold of it. Then use that to mold a pour of your metal of choice. You could even do both sides to make a stamping if you have access to a big enough press
  10. stuart in mn
    stuart in mn
    I've been watching YouTube videos from a place in the UK named Retropower. A**** their projects they're building a couple Ford ******s, and they fabricated some hammer forms for making steel fender flares. They used "solid high density epoxy tooling board", whatever that is. :) There are some pictures on their website, or you could look through the videos on their YouTube channel. (Yes, the cars there are off topic for this board, I'm just pointing at the method they used which would be universal for any car.) https://retropower.co.uk/2022/03/07/project-one-mk1-******-bdg-restomod/
  11. RMONTY
    RMONTY
    Depending on the intricacy of the panel, the line, curves, etc, why not have a skilled woodworker make a hammer form out of MDF. Or better yet, certainly there are CNC type routers out there that could do that easily. Once the file is built, it is eternal. Maybe you are just looking to do it all yourself. Good luck and keep us posted!
  12. I could carve it out of wood, I’ve made others from wood before and they are good for 2 maybe 3 copies.
    I already tried MDF for this one, get 1 good part and the mdf details goes away.
    That’s why I’m looking for something more substantial
    Driver50x and RMONTY like this.
  13. RMONTY
    RMONTY
    Do I remember right, that you printed off a crossover pipe or for an intake or something using a local college's resources several yrs ago? Or am I dreaming? If that was you, what about going that route to get the file made, then find someone with a woodworking CNC router?
    31Vicky with a hemi likes this.
  14. saltflats
    saltflats
    from Missouri
    Would metal to metal body filler hold up for this?
  15. 31Apickup
    31Apickup
    You may have to experiment, there are a number of newer epoxy and polymer products out there that may work.
  16. PhilA
    PhilA
    Agreed, mdf is very malleable; you need something that is able to absorb that shock and spring back to shape (or not be deformed in the first place).
    An epoxy bonded material (maybe like solid kevlar paneling) would likely do well to repeatedly operate as a good buck for modest gauge steel.
    Something like that has the advantage to can be screwed to a workbench or such to prevent it from deforming or shifting as you work the piece. Also the metal can be attached to it to prevent it from shifting.
    Phil
  17. That was me, and this is too big for that facility.
  18. Chief 64
    Chief 64
    rod1 and Happydaze like this.
  19. That’s a commitment there !
    anthony myrick and Johnny Gee like this.
  20. PhilA
    PhilA
    I'm impressed it can do that without tearing the metal.
    Hudson31 and anthony myrick like this.
  21. saltracer219
    saltracer219
  22. Johnny Gee
    Johnny Gee
    from Downey, Ca
    That’s why Anthony is still swinging a hammer on his wife’s 56.
    427 sleeper and anthony myrick like this.
  23. bchctybob
    bchctybob
    Back when I was in aerospace we used to use “dental cement” for temporary casting and filling. I don’t recall the product name. That stuff was tough. You could conceivably form sheet metal over it. If your mold needs sharp edges I think they would be prone to chipping away if abused but it is repairable.
  24. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Why not contact one of the companies that does the sheet forming in @anthony myrick video and get a quote for making a "production run" for you? Might be cheaper in the long run than trying to do it yourself.
    alanp561 likes this.
  25. Johnny Gee
    Johnny Gee
    from Downey, Ca
  26. I just tossed that out there.
    Tooling for a stamping is crazy high.
    I bet this is cheaper but probably still very expensive
  27. ekimneirbo
    ekimneirbo
    from Brooks Ky
    I think you should tell your wife that you need one of these machines to make replacement panels for her 56 Chevy........and then moonlight parts for Hambers.........
    OR
    Tell the school where you teach that this is "the new thing" in autobody parts and get them to buy a machine so you can teach students about the new technology...........:D
    alanp561, Okie Pete, Dedsoto and 3 others like this.
  28. How about a 'composite' form? There are some pretty tough 'reinforced' concrete mixes out there (using such as epoxy binders), use that as a 'base'. Then when pouring, embed steel 'edges' into the form for the raised details to prevent chipping. You may have to start with a fibergl*** mold to get a mold to pour into. It may make a difference also if the form is a 'inny' or 'outy' form, i.e. are you forming over it or into it.
  29. Ebbsspeed
    Ebbsspeed
    90 minutes for a single Figur produced hood vs 240 hoods per hour with a traditional automotive metal press. Good for prototyping or one-off deals, but not ready for prime time in the manufacturing business.
    Kerrynzl, 2OLD2FAST, j hansen and 3 others like this.
