Projects I wish it was this easy! (MOCK UP)
Discussion in 'The Hokey Ass Message Board' started by Sam F., Sep 30, 2008.
  1. Kail
    Kail
    from Austin, TX
    did you lengthen the door or put 2dr doors on?
  2. JimA
    JimA
    Simply- WOW! Amazing work.
  3. DRD57
    DRD57
    I love the proportions on that top. Great job.
  4. Flipper
    Flipper
    from Kentucky
    Are you going to keep this one?
  5. Sam F.
    Sam F.
    THANKS FELLAS!
    Kail,,i used 2dr doors & part of the quarter panel and roof from the 2 dr as well...
    Flipper, yes.
  6. Dat Dirty Rat
    Dat Dirty Rat
    You RULE...awesome metal fabbing skills holmes!!..
  7. junkyard junky
    junkyard junky
    Looking better everyday. Seems to be coming together pretty fast. The shopped top is probably pretty easy after a few cars.:D
    I bet your dad is happy seeing you get those 2dr parts off. That means there is one less car in the barn or just one more space to fill up with another one. lol.:eek::D
  8. tommy
    tommy
    Holy ****! I was admiring the roof so much I never noticed the welded doors. That came as a shock. That is the first car I ever drove.(before):D You did make a silk purse out of a sows ear. My compliments.
  9. Kilroy
    Kilroy
    from Orange, Ca
    Looks great Sam. As always...
    Deep ****** maroon over gold flake... With a gold flake top?
    Or something closer to "STOCK" Ha, Ha, Ha... ;)
    I never thought I'd EVER even think this, but that might even look kinda cool with a continental kit...
  10. 60'shotrod
    60'shotrod
    Fan******tastic!Great work Man.YES TO FLAKE PAINT!
  11. fab32
    fab32
    Sam, You've got to stop doing this..................at least long enough to really finish one of these and get to drive it. You must have been a good baseball player "cause you're batting close to 1.000 with this custom car thing.:cool::D
    Frank
  12. Gator
    Gator
    from Statham Ga
    You've always got the coolest **** Sam!
  13. dieselc
    dieselc
    from ohio
    That is a good lookin car.
  14. SlowandLow63
    SlowandLow63
    from Central NJ
    DAMN! Boy that looks sweet. I do agree, 1 inch lower in the rear and that thing will be *** on wheels. Just put air shocks in it and youll be fine like that.
  15. CanyonCarver
    CanyonCarver
    from So-Cal
    The before and after shots tel l the story. Good luck with the rest of the project.
  16. slammed
    slammed
    It has the perfect profile. Mod, but not radical. And the metal workmanship is top notch.
  17. myke
    myke
    from SoCal
    Nice work!
  18. Sam F.
    Sam F.
    wow!,thanks for all the cool replys guys!
    i didnt even expect all the kind words when i posted this ,,i was just really digging on the mock up shots and wanted to share!
    apreciate it fellas,,,makes all the *$&#@! nights worth it! :D
  19. im real impressed with this car!
  20. JEPPA
    JEPPA
    It turned out amazing. Perfect llines. Forgot it was a four door. Your hard work really paid off.
  21. ....lookin' good Sam..... the chop looks awesome.....
  22. Squablow
    Squablow
    Can I ask a technical question?
    When you added the rear quarter section, where did you tie it into the roof? And if you would have had access to the whole roof from the 2 door car, would you have used it, or would you still have done it with just the quarter section? Let's ***ume you weren't going to chop it.
    I ask because I have a '57 Chevy I'm going to do and the plan was to use the whole roof but now I'm wondering if doing it this way makes more sense. With the '60 Plymouth the quarter piece fit right in but the 57 would require more cutting to do it that way, to eliminate the 3rd pillar.
    I suppose the quarter window gl*** on your chopped car won't have to roll down now that it has canted B-pillars (which look great, btw) but I'd like to have functional quarter windows when finished. I've seen it done both ways but I'm not sure which is going to be easier.
  23. fiftyfiveford
    fiftyfiveford
    Looks awesome, when are you putting it up for sale?:p
  24. Sam F.
    Sam F.
    originally, i was going to use the entire 2 dr roof from the parts car but when i went to cut the quarters off the parts car.the roof was alot worse looking than i had remebered,it had heavy surface rust and dents all over it,
    so i decided to just use my roof along with the quaterwindow drip rail area from the 2dr(so i have an upper window channel and correct shaped drip rail,.)
    i cut a couple inches ahead of the B pillar and about 2 1/2" above the drip rail all the way across parrelel to the drip rail.
    when i cut the quarter panels out from the 2 dr,i cut them out along with then inner quarters so from the inside of the car it looks like a 2 dr (ie bracing,window reg,etc)
    ,,however, as far as the quarter windows i'm not that far along yet,but i think i may be able to get the quarter windows to roll down(at least somewhat) i'm sure it will take some figuring
    on your 57.,,i know what you are saying about the 3rd pillar,.....
    ...it may be more work,but probably better off using the 2 dr roof if its a good one..much cleaner in the end.
    i think ,might be wrong,but i think that 2 dr & 4 drs in 55-57 have different size windshield & rear gl***..
    the shinny area over the drip rail is were i made the cut
  25. zbuickman
    zbuickman
    looks just right to me .... Awsome job I bee watching the frame mods to make this work.... You Da Man
    I dont see why they couldnt??? take a look at the rear windows on the 40's ford tudor sedans. they rolled up and then back. dont see why something cound not be retrofit or even regulators put in at an angle theres ways to do it:)
  26. Squablow
    Squablow
    Thanks for the response. I've seen tri-5's done both ways so I wasn't sure. The roof on my donor car is pretty clean so I probably will use it all in one piece. The windshield and rear window gl*** is the same between the sedans, only the hardtops are different.
    So you did have to cut up into the roof skin. I was wondering about that. Seems like it'd be tough to get everything lined up square that way, but it sure looks nice. Can't wait to see it finshed.
