Hot Rods Id a 350 sbc.
Discussion in 'The Hokey Ass Message Board' started by okiedokie, Jan 15, 2021.
  1. okiedokie
    okiedokie
    from Ok
    After searching to normal sites I have been unable to pin down exactly what his engine is. Head casting number is 14101083. Wondering if it is a roller cam. engin casting nmbers 1.jpg engine casting numbers 2.jpg
    Deuces likes this.
  2. squirrel
    1986 truck engine, so not, it's not going to be roller cam
    mgtstumpy and Deuces like this.
  3. okiedokie
    okiedokie
    from Ok
  4. warhorseracing
    warhorseracing
    from cameron wv
    Easily identifiable as a non corvette engine by the lack of orange paint.:)
  5. Mr48chev
    That don't show the grease and oil so bad black. I had a buddy who thought that was the only color you could paint an engine no matter what color it was supposed to be.
    Those truck engine suffix codes are sometimes hard to find unless you use the same source Jim has.
    Deuces likes this.
  6. Penetrator
    Penetrator
    from SK CAN
    Brilliant. Thanks for your expertise.
    Deuces likes this.
  7. warhorseracing
    warhorseracing
    from cameron wv
    You are quite welcome Sir.:D
    Deuces likes this.
  8. Budget36
    Budget36
    083 heads were on '87?-'92 F-Bodies.
    Deuces likes this.
  9. 1971BB427
    1971BB427
    from Oregon
    Not a roller, but maybe a 4 bolt main since it's a truck engine.
    Deuces likes this.
  10. Mr48chev
    That may depend on who's cylinder head chart you look at.
    Chevy Hard core says : 14101083: 1987 350ci. Originally came on crate engines with 285 hp or 300 hp. 64cc chambers, 72-degree center manifold-bolt angles.
    That from here (one I hadn't used before) Swap Meet Guide To Small-Block Chevy Cylinder Head ID (chevy********.com)
    Mortec says :
    14101083...87-up...350..........Gen.I, also used on crate motors, 285 or 300 hp, 64cc
    chambers, 72' center manifold bolt
    angles
    With the factory applied serial number and suffix code on the block the crate motor thing doesn't jive very well. Checking the Mortec site I'd say the Chevy ******** guys ***umed rather than researched.
  11. okiedokie
    okiedokie
    from Ok
    Thanks guys, it is a very clean, low mileage engine. No reason to take anything apart to find out if it a roller. Just wondering if I need high zink oil or not. I paint all my engines black, no matter who built them.
  12. Budget36
    Budget36
    I’ve an ‘89, well, my kid does now that I bought new. Has 083 heads on it. I also think they were available on some crate engines as well
