Hot Rods ID a Chevy 350 Piston #1754 - Manley?
Discussion in 'The Hokey Ass Message Board' started by shop teacher, Apr 22, 2017.
  1. shop teacher
    shop teacher
    Hi- anyone have old engine part catalogs that can ID a Chevy piston with number 1754 marking on top? I picked up a set of Chevy forged .030 pistons along with a set of Manley aluminum rods- maybe Manley pistons? They look to be balanced as material in removed on the rods and inside the piston dome. The rod bolts are also clipped. The piston skirts are in excellent shape -almost thinking that they have never been run. Thanks
  2. 56sedandelivery
    56sedandelivery
    Rod bolts "clipped"? Sounds like a stroker combination, like a 350 to 383.
    I am Butch/56sedandelivery.
  3. indyjps
    indyjps
  4. Rory Welcher
    Rory Welcher
    Did you find out what the pistons are i also have a set with 1754P on the top
  5. BOBCRMAN
    BOBCRMAN
    from Holly
    The 2252a and the 1754 are the same piston. High compression 350 chevy with a standard length (5.7) con rod.
