Hot Rods ID a Joe Hunt Ford FE??? Magneto--
Discussion in 'The Hokey Ass Message Board' started by ssaza25, Feb 27, 2025 at 12:18 PM.
  1. ssaza25
    ssaza25
    from arizona
    I picked up this magneto, was told that it fit a Ford FE motor. After doing some research, I found out there are few different ford distributors that will not interchange. Any help to ID this joe hunt Magneto? Has a vertex cap. The tag has nothing stamped on it for model # or serial # stamped 0675F8E9-A0B3-46CC-AD82-5232090F9482.jpeg .
  2. Oneball
    Oneball
    It doesn’t have the normal type of seal for an FE distributor and they don’t usually have the shoulder above it either but I guess as it’s aftermarket that may not be definitive.
  3. squirrel
  4. ssaza25
    ssaza25
    from arizona
  5. Malcolm
    Malcolm
    from Nebraska
    Just FYI, a small block Ford version looks very similar to the FE version. Dimensionally, I don't know the differences, though.
  6. Flatrod17
    Flatrod17
    It looks like my small block mag. What size is the oil pump shaft? Small block and FE will be 1/4, if it is 5/16 it is maybe 351W. Also 460 as well as 351C would be 5/16. It is not FE.
  7. Flatrod17
    Flatrod17
    Also, there are gear diameter differences between the small blocks. If you can measure the gear od more info can be given.
  8. Flatrod17
    Flatrod17
    Looking at it again I am going to say it is 460 Ford, being that tall. It will also fit a 351C if it is 460.
  9. ssaza25
    ssaza25
    from arizona
  10. Flatrod17
    Flatrod17
    460 and 351C have that size gear, but so does FE. It is not FE, housing is shaped wrong. I am pretty sure it is 460. It should have the 5/16 oil pump shaft size. When I go back down into the shop tomorrow, I will measure up and give dimensions. There is a off chance it could be 351W.
  11. ssaza25
    ssaza25
    from arizona
    It is 5/16"oil pump shaft size.
  12. Flatrod17
    Flatrod17
    Looking at all my distributors I am pretty sure it is 460.
