ID: Are these Lincoln Drums and Backing Plates?
Discussion in 'The Hokey Ass Message Board' started by alvisoroadsters, Nov 26, 2007.
  1. alvisoroadsters
    alvisoroadsters
    from Cupertino
    i've been wrangling parts out of my backyard and stumbled on these. i couldnt tell if they were lincolns or what, so i was hoping someone could identify these for me?? thanks everyone.
    and heres a closer look at the fins.
  2. Bruce Lancaster
    Bruce Lancaster
    Thems is '46-8 Ford...angle makes it hard to see, but I think '32-4 spindle
  3. alvisoroadsters
    alvisoroadsters
    from Cupertino
    thanks bruce, by any chance do you know if they happen to be self-energizing or not?
  4. VAPHEAD
    VAPHEAD
    Not self energizing.
  5. bbtrux
    bbtrux
    and not 32-34 spindles either.
  6. alvisoroadsters
    alvisoroadsters
    from Cupertino
    sick, that clears up the mystery. im thinking about running them on my 35 ford truck, i'm ***uming since theyve came off a later 40's ford due to the size of the vehicles, they probably stop pretty decent?
  7. NealinCA
    NealinCA
    Why not? The sure look like it to me...integral upper steering arm and all.
    Neal
  8. alvisoroadsters
    alvisoroadsters
    from Cupertino
    i believe those are '33-'34, are those brakes a decent pick?
  9. Andy
    Andy
    Hubs,drums,backing plates are all 46-48 Ford.
    The spindles are 32-34. The backing plates have been redrilled and rotated for the early spindles.
  10. alvisoroadsters
    alvisoroadsters
    from Cupertino
    do the brakes stop well? or better than say an early 40's juice brake?
  11. VAPHEAD
    VAPHEAD
    39-48 all stop the same.
    Those being later are easier to adjust.
    And it looks like the stock holes are still there.
    Pull them apart,sand blast,have the drums turned.
    PM me if you want all the parts to rebuild,shoes w/c etc.
  12. Andy
    Andy
    They really stop the same. The drums might be a bit better and they are easier to adjust. They used bigger wheel cyl. but you can only buy the bigger cyl. now so no difference. I think the drum fins are great. That one hub is damaged and probably not usable. The spindle is suspect also. The hub is steel so might be straightened.
  13. alvisoroadsters
    alvisoroadsters
    from Cupertino
    perfect, thank you andy and vaphead. that clears up pretty much everything i wanted to know, except whats the process for hub straightening? and when it's time to rebuild the front end ill let you know and get the stuff.
  14. VAPHEAD
    VAPHEAD
    Andy,I don't see what you see.
    Where's the damage?
  15. Andy
    Andy
    You are right Eric! I looked at it and thought there was a gap that was just the humps on the drum. All is well. Sorry.
  16. Royalshifter
    Royalshifter
    Moderator
    Definately 46-48 Ford, I have the exact on my A coupe.
  17. alvisoroadsters
    alvisoroadsters
    from Cupertino
    haha awesome. less work. thanks for all the help guys, and eric when i drag the 35 here to california and start hanging the front end ill definitely send you a message on the rebuild parts. thanks for all the help!!
