ID Artillery Wheels
Discussion in 'The Hokey Ass Message Board' started by mike hamel, Feb 14, 2009.
  1. Kevin Lee
    Kevin Lee
    Super Moderator
  2. mike hamel
    mike hamel
    I am well aware they used a number of different wheels. The most common where kelsey hayes wire wheels and 1940 ford steel wheels. You rarely saw any ARTILLERY style wheels on cars, and when you did. It was the 16x4.5 kelsey hayes ford 5x5.5 wheel.
  3. DE SOTO
    DE SOTO
    I dont wanna make this an argument over what is what, But the first pic of the CLEVE_WELD style wheels that you said are KELSEY-HAYES is a completely different wheel than the Second picture you posted.
    The First pic woth the Chrome centers look EXACTALLY like my CLEVE-WELDS.
    your Second pic looks like a pair of Ford General Jumbos & a Chevy KELSEY-HAYES.
    I have & have had Alot of old wheels, Currently Looking for a pair of 16" Ford b/p Solid wheels called THE GENERAL made by CLEVE-WELD.
    They are an All solid wheel with a BIG oversize General Jumbo style cap that says THE GENERAL on it.
    And another Lil tid-bit is GENERAL JUMBO wheels are made by CLEVE-WELD.
  4. mike hamel
    mike hamel
    Ok I will clear this up right now. The first wheel that i will be posting is of a 16x4.5 Chrome centered Cleve-Weld Wheels. They are 5x5.5 bolt pattern too.
  5. mike hamel
    mike hamel
    These wheels are the Kelsey Hayes 16x4.5 5x5.5 bolt pattern. These are also chrome center wheels too. These wheels also can have clips instead of a ring like the wheels pictured.
  6. mike hamel
    mike hamel
    I am not an expert on these wheels and would like to know if anybody might know or would know where I could find more? They are 18" in diameter.
  7. Weasel
    Weasel
    They look like early thirties Studebaker to me.
  8. mike hamel
    mike hamel
    Thanks Weasel! That is exactly what I was thinking actually. I heard from someone that they might be a Firestone manufactured wheel. I do not know for sure? For now I will be sticking with Studebaker.
  9. Clark
    Clark
    Any clue as to what this wheel is? It's not a Goodyear Airwheel. Similar but different.
    I'm looking for a single Clark wheel. They have a split rim. I have pictures if you are unfamiliar with them.
    Clark
  10. Clark
    Clark
    I'm pretty sure Weasel is correct on the Studebaker wheel. The Firestones where 16 and may be the same as the Clark wheel. Here's a pic of the Clark's.
    Clark
  11. mike hamel
    mike hamel
    Hi Clark, that is a very un-usual wheel that I have never seen before. It looks like they used an artillery wheel and filled it in. Look at the back side of the wheel. Do they have a wheel cover on them?? I have wheels that look similar to that one. I have seen those clark wheels but I do not own one. Yes they are split rim.
  12. Clark
    Clark
    Yeh...The back looks like an artillary wheel. I don't have the caps for them and the opening is a little larger than the Airwheels. I have a pair (wish I had 4). They are 5x4.5 bolt pattern.
    Clark
  13. mike hamel
    mike hamel
    That is one of the most unique wheels I have seen, I am sure you would love to have 4, I know I would! I will keep an eye out and if I come across one. I will definitely let you know. I will help whoever out with artillery wheels they are looking for!
  14. AMC360
    AMC360
    from Canada
    These rims are from a Terraplane but 36 had 5 lugs. Must be older.
  15. Weasel
    Weasel
    I have an artillery wheel related question: It was common practice to paint decorate artillery wheels - some of it is pinstriping but other patterns appear as if they were painted with a stencil. Does anyone know of a source for stencils for artillery wheels?
    Here are a couple of samples: 1936 Willys Model 77 Kelsey Hayes wheel , 1933 Willys Model 77 KH wheel - no holes, and pinstriped Packard wheel.
  16. 35 Woodie
    35 Woodie
    I snagged a set of 5 of what I believe are Kelsey Hayes 16" x 4.5" wheels, 5 bolt on 5.5" circle, on e-pay about 3 years ago. One has never had paint on it!
    I removed the center rings for a small hubcap and inserted ****on head fasteners to hold these Mercury caps.
    I'm trying this Krylon rattle can "khaki" color as I want to do something else other than red or black wheels on my black deuce nailhead hiboy. I'm going to run Firestone blackwall 550-16s on the front and 750-16s on the rear.
    ehdubya likes this.
  17. alchemy
    alchemy
    Check this (lifted from the HAMB years ago).
  18. Carter
    Carter
    18x3.25, 5 on 5.5 BP Firestone wheel.
  19. mike hamel
    mike hamel
    Hey!!! Yes that look was called "Sunburst" that you could get painted on the wheel when you went to purchase your wheels new. I would take your wheels to a local pinstriper to have him do it. I know a guy in reno who would be great at duplicating the "sunburst" look.
  20. mike hamel
    mike hamel
    If anybody has a picture of the firestone wheels actually mounted on a car please post that!! I really like that wheel and am looking for one more. Please respond!
  21. Weasel
    Weasel
    Jimmy Shine's pick up uses them, with 1933 Ford V8 hub caps.
  22. mike hamel
    mike hamel
    any more help??
  23. lrs30
    lrs30
    from Kentucky
    Can you show a pic of where you put the ****on heads .... I'm wanting a set of caps for mine and am having no luck as of yet.. I have a set of baby moon caps I am thinking of putting on them just have not come up with the time to do it yet....
  24. mike hamel
    mike hamel
    Just picked up a set of 4 perfect wheels like on Jimmy Shines Truck. They are 18" Studebaker wheels.
  25. Hot Rod Michelle
    Hot Rod Michelle
    I wanna play too. But, I've got to dig the wheels out of the shed first.
  26. 35 Woodie
    35 Woodie
    Sorry for the delay in answering. Here is the wheel with the hubcap removed. I took careful measurement of the diamete of the cap where it contacts the "bumps" on a Ford wheel and transferred that lcoation to the artillery wheels. I then drilled and tapped 4 holes to insert the ****on head machine screws. They hold very well but, just for a little insurance, I may add a small bead of silicone where the cap seats on the wheel.
  27. mike hamel
    mike hamel
    Hey! Yes thats very cool! Those wheels are 16x4.5 Kelsey Hayes Ford Artillery Wheels. The are 5x5.5 hubcap. Those screw might allow for a momre popular hubcap to fit on the wheels. I have only seen about 2 wheels with hubcaps on it. The regular ones are impossible to find! Rare wheels!
  28. lrs30
    lrs30
    from Kentucky
    great tip thanks for the info
  29. hotrodjeep
    hotrodjeep
    Mike,
    I was just about to post my own thread on these,but maybe you and your wheel friends can take a look first.
    They came off a homeade trailer, so I also have the front axle, splidles, and brakes
    16" w/ 5x5.5 bp
    VERY heavy compared to std steel wheel.
    Spokes are rivited to rim.
    Hubcap clips are attatched thru a slotted hole then scewed in.
    I can peel a tire off this weekend if I need to.
    Thanks for any help.
    Jeff
  30. bshepherd
    bshepherd
    from michigan
    I just came acrossed one trying to figure out what it is. Its 16"x5" six lug got it and a pair of brand new Dilly hubcaps. Ill post a pic later today
