Hot Rods ID help needed 32 Plymouth
Discussion in 'The Hokey Ass Message Board' started by vintagedrags, Feb 14, 2010.
  1. vintagedrags
    vintagedrags
    A buddy of mine is building this 32 Plymouth three window.
    he's putting this 1957 392 hemi in it.
    After pulling the car apart, he couldn't figure out what the rear axle was. Can the HAMB help him id it? Here are some pics.
    Thanks for the help!!
  2. Hnstray
    Hnstray
    from Quincy, IL
    It's a mopar rear axle. I don't know how far back they used that style companion (pinion) flange, but it was up through the late 50's for sure. The driveshaft has a "pot type" u-joint, which is quite unconventional looking, but is a stamped steel housing with the driveshaft sticking into it with a crosspin, and it provides both lengthwise movement and U-joint angle allowance and the end of it is a flange fitting that bolts to what you see on this rear end. This unit could be from any Plymouth, Dodge, DeSoto from at least the 40's (maybe 30's) thru the mid 50's.
    Ray
  3. Yup that's an Mopar 8 3/4 with a trunion style universal joint, probably late 50's early 60's.
    Very cool car and I hope it stays all mopar!!
    Please ask him to start a build thread so we mopar lovers can follow along from home....;)
  4. moparforlife
    moparforlife
    from Rolla, MO
    I'll agree it's an 8.75. Has to be older than '66 because the flange style was dropped after '65. What is the case number on it?
  5. DirtyWoody28
    DirtyWoody28
    My buddy had a 54 desoto, and the rear axle looked very similar.
  6. el Scotto
    el Scotto
    from Tracy, CA
    It looks like an 8 3/4, but it isn't. The ring gear is actually a bit smaller, I can't remember the number offhand. Not sure when the popular muscle car styled 8 3/4 came out, but it was late 50s or early 60's.
    That could quite possibly be the original rearend for that car!
  7. squirrel
    looks like what was in that 39 plymouth we used to have. Look at the numbers on it...they're probably hiding under a lot of grease...if you care. You'll want to swap in a newer rearend, most likely
    also when asking for ID help, you might want to include pics of the whole rearend, including the brakes, there might be more clues
  8. moparforlife
    moparforlife
    from Rolla, MO
    The case number would help a lot as far as year ID. The 8.75 was introduced in 1957. The last 3 case numbers could be 741 (or 657),742 (or 985),489 (or 488), each corresponding to a different pinion stem size. The numbers in parenthesis are the same pinion stem size, but different years.
  9. vintagedrags
    vintagedrags
    Thanks for the info, Dave is going to clean the grease off and get me the numbers. I will post them along with some pics of the brakes.
  10. AllSteel36
    AllSteel36
    Another thing to look at, which is tough to see, is if the hubs on the rear are pressed on (like a Ford banjo rear) or if the studs are part of the axle...I have a '32 PLymouth axle, and they are tapered fit like the older Ford.
  11. squirrel
    Mopars used tapered axles/hubs from the 30s (or earlier) to the early 60s
  12. AllSteel36
    AllSteel36
    I'll be darn, I thought that (tapered fit) wasn't used after the late 40's.
  13. filthy frank
    filthy frank
    nice car to start with !
  14. 48MOPARCPE
    48MOPARCPE
    That rearend looks like the stock rearend I took out from under from my '48
    Plymouth coupe. The rest of the car looks to be in great shape. To be Mopar
    engined? Just say no to uncle GM or his Blue cousin!
  15. vintagedrags
    vintagedrags
    To be Mopar engined? Just say no to uncle GM or his Blue cousin!
    Hell yeah all MOPAR!! Thats what the hemi is for! :D
  16. oldebob
    oldebob
    from Spokane WA
    Those '32 model PB Plymoths are good looking cars. That one looks in great shape.
  17. kookee
    kookee
    Any updates? Does you friend plan to keep it full fendered?
  18. vintagedrags
    vintagedrags
    No recent updates at this point, but I do know he's not keeping it full fendered.
