Hey Found this Add a guy trying to sell a gearbox: Gearbox for sale, might be OD, might be reduction. please respond with ID. It looks like a brownie type box, to give you more gear is an truck, just what i need. but wants to make sure before purchase.
No markings or numbers? looks like a bellhousing type mount, but no spline? Maybe converted to power unit type use.
I have seen trans like that used on lathes, drill presses, mills, to have better speeds. Maybe converted to belt drive.
I write the guy and ask him for any numbers or casting markes. But that at the bottom is a PTO, right? Looks like a truck box with a modified high speed axle.
Owner returned my mail. Explaining that it had a speed drive marked with the Blue arrow. He explains me that the two lower arrows is for engaging PTO and PTO shaft. I knew that already. He things it's a four speed and it has a reverse lock out. Top arrow shows where he found cast name and number: J.R. Huni 7059788 I can see it's a truck tranni with PTO. And has a modified high speed axle. It dosent look like that fit any car application.
Doesn't really look like an automotive application, more likely for a piece of industrial or ag equipment.
41-47 chevy truck transmission, but modified to be used in some other application. No synchros in that one, either.
So not worth much, not a damn better then my 4 speed there already fits!!! No need for that extra headache. Thanks guy, @squirrel a trooper as always. And thanks to everybody else!!
I don't know if a should feel embarr*** to ask silly questions, or be proud that I know how is smarter them me, and dare to ask. For now I go with the latter. [emoji41][emoji111]️
I mean the questions that are easy for me. Because I had one of those, or something similar. We each know about different stuff...
It's just that Squirrel has a lot of different stuff! Always amazes me the things Squirrel can figure out or contribute knowledge about.
