Customs ID these wheel covers?
Discussion in 'The Hokey Ass Message Board' started by RMR&C, Sep 5, 2022.
  1. RMR&C
    RMR&C
    from NW Montana
    I have a pair of these sombrero type covers, would like to find a couple more. Guessing 60s vintage? They are 16 inch.
    Thanks.
  2. Black Panther
    Black Panther
    from SoCal
    1961 Cadillac minus the emblem.
    Bob Lowry likes this.
  3. 302GMC
    302GMC
    from Idaho
    Now, officially, every Cadillac wheel cover regardless of YOM, is a sombrero ....
    X38, Bob Lowry and '28phonebooth like this.
  4. Squablow
    Squablow
    These fit a special 15" wheel that looks like a reverse offset wheel. If you've got a car with 5 on 5" pattern, and if you can find a matching set of the original 61-62 Cadillac steel wheels, these would look good on something custom, but don't expect them to fit any other steel wheel (maybe there's something else out there that these would fit on, but 99.9% of steel wheels aren't going to take these).
  5. Jer Barlow
    Jer Barlow
    You guys absolutely sure this isn't a bundt cake pan??
    Cosmo49, ClayMart, Johnny Gee and 5 others like this.
  6. Um....OK @302GMC you have obviously been sleeping during the "Automotive Truism" sessions here, but..... ALL SBC 327 engines are Corvette, if it ain't a Ford or Shuvellay it's a DODGE, and yes Virginia, ALL Cadillac wheel covers are Sombreros. Please make notes for future reference.
  7. RMR&C
    RMR&C
    from NW Montana
    I'm curious how these fit a 15 inch wheel. They won't even fit a 16?
  8. 302GMC
    302GMC
    from Idaho
    They got 100s of tiny claws that grip the curve on the extreme OD of the rim .... designed so normal balancing weights won't work.
    RMR&C and Squablow like this.
  9. Squablow
    Squablow
    They go right up to the edge of the tire, no exposed rim with these on. Keep in mind, if you measure the very outside diameter of a 15" wheel, it'll be a bit over 16 inches, the wheel/tire diameter is measured on the inside of the bead lip, not the overall diameter of the wheel. I ***ure you, these fit a 15" wheel.
    RMR&C and egads like this.
  10. ROBRAM
    ROBRAM
    And all cars from the 30's are 32 Fords.
    '28phonebooth likes this.
  11. 51504bat
    51504bat
    And they all ran when parked.
  12. And...."Not for sale, my kid an' I are gonna fix 'er up one of these days."
    51504bat likes this.
  13. RMR&C
    RMR&C
    from NW Montana
    Thanks to all for the ID and info. Has anyone ever tried to adapt these to different wheels?
  14. squirrel
    this is what the wheel looks like, I expect most wide "reverse" type wheels will work with them...but try before buying, if possible.
