Hot Rods ID these wheels
Discussion in 'The Hokey Ass Message Board' started by Kiwi 4d, Feb 22, 2024.
  1. Kiwi 4d
    Kiwi 4d
    Can anyone ID the origin of these 15” wheels , I had them marked as mopar but they could be anything. The car has what I believe to be a 9” rear , but the axle centre boss is too big for a 49 type ford wheel to fit over.. The hub cap nubs while hard to measure accurately only being 3 are approximately 9” od. IMG_2845.jpeg
  2. DDDenny
    Utility trailer!
  3. gary macdonald
    gary macdonald
    Studebaker, and Chrysler had similar looks .
  4. Bandit Billy
    Bandit Billy
    Did you ask Adam?
    clem, Oneball and Paul like this.
  5. nosford
    nosford
    The early Mopar wheels look like that but have clips for the hubcaps rather than nubs. I would think Studebaker as well.
  6. wheelkid
    wheelkid
    Alliance Vendor
    from Fresno, CA
    Late 50s-early 60s Plymoth
    Kiwi 4d and squirrel like this.
  7. Kiwi 4d
    Kiwi 4d
    Nice one @Bandit Billy . Adam has moved out of the country.
    Bandit Billy likes this.
  8. Squablow
    Squablow
    He's saying they're 15 inch, did any Plymouths from 55-64 have 15" wheels? They do look like the ForwardLook wheels I have, but all of the ones I've ever found were 14's. Would these be the 55-56 specific wheels, post-clips but pre-14"?
  9. daliant
    daliant
    Is there a pentastar stamped near the valve stem?
  10. caprockfabshop
    caprockfabshop
    55-56 Mopar had 15" rims, but they had the tabs on the inside like this:
    And since your rim doesn't have those rivetted tangs, I'd say it's not Mopar. I would personally believe they're utility or camper rims, since they often were made in the common 4x4.5 bolt pattern.
    Deuces and Squablow like this.
  11. Hnstray
    Hnstray
    from Quincy, IL
    1955/56 Mopar cars had 15” wheels. 1957 ushered in the Big 3 switch to 14” for most of the p***enger car models.
    Ray
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Deuces likes this.
  13. They could also be Hudson. Hudson used dowel pins to locate the wheel and attached the wheel to the hub with lug bolts rather than studs and nuts.
  14. Fortunateson
    Fortunateson
    I don’t see any of the holes that Chrysler products use for the aligning pin where ch helps a lot when bolts are used. I wish my OT German —- had them!
