ID this Blower Flathead??
Discussion in 'The Hokey Ass Message Board' started by deucerails, Feb 7, 2009.
  1. deucerails
    deucerails
    from Manitoba
    A FNG question, a friend of mine has this old blower, no markings on it that i can find, looks similar to a SCOT unit but has some differences (Judson maybe?). does anyone know what make this blower is? does it have any value? does anyone have dimension for a SCOT blower for me to compare it to?
    Any help would be appreciated. Thanks
  2. Flat Ernie
    Flat Ernie
    Tech Editor
    Doesn't appear to be a SCoT and does look rather large to be a Judson (although I understand they came in different sizes). Looks very mil-industrial - perhaps aviation related?
  3. HR Classic Cars
    HR Classic Cars
    from Wylie, TX
    Don't know what it is, but that looks great..
    I can think up several projects that would be a great addition to.
    So yes, it has some value, just because it's a little different.
  4. Little Wing
    Little Wing
    from Northeast
    Judson never made a twin far as I know
  5. robt500
    robt500
    from Lex, KY
    I don't know but the fins are awesome.
  6. budd
    budd
    my guess is thats a blower from a compressor. not off an engine.
  7. kelzweld
    kelzweld
    I've no idea what it is, but I believe a number of European marques made their own blowers in earlier years. One thing to look at that may give some idea of where in the world it came from is whether the fasteners are imperial or metric.
  8. Screamin' Metal
    Screamin' Metal
    from Oklahoma
    Budd, you da man! These have been used for years for blowing things thru ducts and piping, etc........fibergl*** in mills, wood chips, or as a vac*** source for ****ing things thru ducts and pipes.........
  9. deucerails
    deucerails
    from Manitoba
    Budd and Screamin' metal can you explain further? as in a shop air compressor for running pneumatic tools?
  10. 1952henry
    1952henry
    Not to argue, but I'm wondering if it is a Schwietzer supercharger from an early ***mins diesel. I know from pictures that they had multiple fins such as this one. In addition, I believe the superchargers were gear driven.
  11. 1952henry
    1952henry
  12. deucerails
    deucerails
    from Manitoba
    does anyone have a picture of this "Schwietzer supercharger" a quick Google search didn't show me much but i'll keep digging
  13. 1952henry
    1952henry
    I misspelled it, I believe it should be Schwitzer. I have seen pictures on the 'net just can't remember where!!, and an early blown ***mins powering a 1951 Mack in person, but I don't remember enough to positively id your unit.
  14. budd
    budd
    heres kind of a ****y pic of the ***mins diesel with a blower, it does look much the same but doesnt have the same front end, and on an engine you would think they would use crankcase oil and not grease fittings.
  15. unkamort
    unkamort
    Dosn't help ID the unit... but the guy is certainly interesting. google#1
    Schwitzer
  16. unkamort
    unkamort
  17. 1952henry
    1952henry
    I may be wrong about the gear drive, it has been awhile since I saw the blown ***mins in person. A far as the crankcase oil, that's a tough call. I think compressors on diesel engines have their own oil supply, but use engine coolant instead of fins like a shop compressor. I st@ 2b corrected.:)
  18. krooser
    krooser
    I believe what you have there is a supercharger from a legendary ***mins NHRS "Iron Lung" engine. These engines came in trucks from the early 50's into the late 60's. Some made their way into industrial applications as recently as the 1970's.
    The NHRS used a disc-style fuel pump which was the predecessor to the PT pump introduced on the NH series engines. The combination of the disc fuel pump and the supercharger made the engine whine like a banshee at full load. In the middle of the night you could pick out the sound of the ***mins "Iron Lung" from other trucks running in a pack... kinda like having a top fuel dragster in the middle of a bunch of Honda's.
    Here's the sound of an 275 HP NHRS Iron Lung at high idle in a Bull nose Kenworth.
    http://www.youtube.com/watch?v=WZDxj8E7acI&feature=channel_page
  19. Screamin' Metal
    Screamin' Metal
    from Oklahoma
    Krooser is right also, and they were also used as blowing and suction devices on heavy industrial applications.
    There's a really large machine behind a bearing facility right outside of Birmingham, Al. and this machine has about 3 or 4 of these blowers on it, being turned by a 200 HP electric motor. See the large bearing housing on the one end??????
  20. Casey
    Casey
    it`s cool looking, and would look great on a flat head.
  21. Bruce Lancaster
    Bruce Lancaster
    I remember seeing roots blowers in 1950's war surplus ads in Pop Mechanics type magazines...they were apparently used to pressurize cabins of airplanes, which would probably mean B-29, Constellation, maybe DC 4 types...not very many WWII panes were pressurized. The ads gave no clue as to size or capacity.
  22. The blower looks a bit like an English Wade unit although I dont think it is. The Wade has an angled outlet . See the link below.
    http://www.bcsc.co.uk/info/supercharging.html
    Also, that Judson supercharger depicted on the You-tube clip appears to be a vane type. Can someone confirm that?
  23. deucerails
    deucerails
    from Manitoba
    its looks like the large Marshall superchargers on these websites, does anyone have more info about these units??
  24. http://www.flickr.com/photos/80652380@N00/391355007/
    Did you try to google marshall supercharger, lots a stuff to read an find, this looks like yours mounted in front of the radiator crank driven, *****en!
    Also try marshall cabin blower , used for light air craft also, retrofitted on british sports cars, that victory site has a lot of info and links
  25. This link shows a schematic of a Marshall blower and looks like the one depicted
    http://www.flightglobal.com/pdfarchive/view/1945/1945 - 1178.html
    Cabin blowers have been used to good effect as superchargers. Below is a pic of a supercharged VW powered hillclimb special which utilised a Rootes type Godfrey Cabin blower. This pic was taken easter 1971.
