ID this Distributor
Discussion in 'The Hokey Ass Message Board' started by tiger mark, May 15, 2010.
  1. tiger mark
    tiger mark
    from burbank,il
    Bought a 60 chevy kingswood with a 283 and cast iron power glide and this came with it. Can you tell me what kind of distributor it is.
  2. BOBCRMAN
    BOBCRMAN
    from Holly
    It's an old cast iron tach drive distrib. Probably for early sbc corvette. Probably worth a fortune on Ebay.
  3. Torkwrench
    Torkwrench
    It looks like it's a small block Chevy distributor, perhaps out of a big truck, 2 ton or bigger???
  4. My Guess Would Be A Chevroelet Truck That Had A Governor On The Engine. The Distributer And Carburetor Worked Together To Conrtol Enginr RPM's
  5. BadgeZ28
    BadgeZ28
    from Oregon
    I don't see a place for a tachometer cable. And no vacuum canister hose connection. Definitely delco window adjust.
  6. dave lewis
    dave lewis
    from Nampa ID
    The delco # is on the shiny metal tag wrapped around the base...visible in pics # 1, 2 and 4.
    Looks to be a governed dist...
    The tag will tell the story !
    Dave
  7. Alright hambers, heres a hands on description of this distributor.....
    What we are looking at Is a plastic oil line (Airline?) Going into a tee with a pressure swich (or such) feeding into to distributor. Looks like an oil feed....
    The large round part looks like a breather cap cause the bottom side (towards dizzy)
    Has holes going around it looking just like a mini oil fill / breather.
    I know if this was a chevy six dizzy, they had a grease cup in that location that you would turn in a few turns every few thousand miles.
  8. This should have a vacume advance nipple, shouldn't it?
  9. I'm thinking truck with a centravac governor. The sender or switch on it is odd but it could be for a truck with a PTO driven accessory that requires a certan RPM.
  10. Mr48chev
    Truck or industrial engine distributor for sure. Not worth much except to someone who thinks they need a governor on the engine in one if their fleet trucks. You could clean it up and throw it on Ebay but I doubt you would get a bid on it.
  11. GMC BUBBA
    GMC BUBBA
    " ditto"
  12. onlychevrolets
    onlychevrolets
  13. FoMoCoPower
    FoMoCoPower
    Mark,lets see pics of your king`s wood
