ID this fuel injector I need another
Discussion in 'The Hokey Ass Message Board' started by LANCE-SPEED, Jun 7, 2011.
  1. LANCE-SPEED
    LANCE-SPEED
    My friend purchased an old Harley drag bike that he is gonna give a new life as a Land Speed bike. It came with (1) injector and he needs another. he knows it is not for a motorcycle, he thinks it may be an old aftermarket
    hot rod part? Also if you know what it is, do you have one for sale? He needs one.
  2. dreracecar
    dreracecar
    from so-cal
    All of the parts (hoses, arms, nozzles, barrle valve) are HILBORN
  3. LANCE-SPEED
    LANCE-SPEED
    Anyone?? A little more specific??
  4. We used to use a single off for a Big Block MOPAR when we ran a single. I have also heard of guys using an injector for a 326 Pontiac.
    I can't see it well enough to tell you for sure. Uploaded pictures I can usually make bigger but linked pictures I can't do much with without downloading them first.
  5. LANCE-SPEED
    LANCE-SPEED
  6. Looks like a hilborn unit cut out of a MOPAR flange. do you know what the throttle bore is?
  7. LANCE-SPEED
    LANCE-SPEED
    COOL, Where would we find 1, just one?
  8. revkev6
    revkev6
    from ma
    with the 7 other injectors attached to the manifold??
    as is common practice with engines that have little aftermarket support, the original maker bought a complete v8 manifold (possibly damaged originally) and cut off the number of injectors that he needed. lots of guys used to do this when they ran vw's one sbc hilborn injection manifold would do two vw engines when cut up.
  9. I'll send you a PM.
  10. RichFox
    RichFox
    If you need one or two of 1.650 or about, I can help you.
  11. Unkl Ian
    Unkl Ian
  12. revkev6
    revkev6
    from ma
    ok I see now, the injector is welded to the head! all you really need is an injector with the correct size. I thought they had found an injector that bolted on. you really just need the id of the injector at the ****erfly and where it aligns with the head. should be able to narrow it down from there. might be easier to cut the injector off and weld up two different ones that you know match. if those ****erflies aren't matched up perfect your idle and mid throttle is going to be a total ********! I've seen it on an injected VW. rattles your fillings out!
  13. LANCE-SPEED
    LANCE-SPEED
  14. crowerglide
    crowerglide
    from Tyler, TX
    Seems like the old Chrysler wedge Hilborn I had was actually two separate pieces that bolted to the heads, not a one piece manifold. I think the early Olds may have been similar.
  15. LANCE-SPEED
    LANCE-SPEED
  16. dreracecar
    dreracecar
    from so-cal
    I found it----HILBORN model #105-O-4A (1-13/16)
    Offenhauser midget engine Its the #2 injector (of 4) because of the BV mounting pad.
  17. RichFox
    RichFox
    One place where there are plenty of cheap throttle bodies is junk yards. Here is a picture of a set on a banger that I made from a 750 Suzuki efi. Also one I made from 4.6 Ford mod motor efi parts. There are thousands of these thinga on Ebay and in junk yards all over. I know Stu got famous and I hope he got rich inventing constant flow fuel injection. But you can buy much better OEM throttle bodies way cheaper all over the place. Still need to go to Hilborn for pump, metering block, nozzles, and all that. Shaft size is 5/16. Throttle arms have 10-32 threads and are on 1.200 centers. I have made a bunch of these for bangers, Chevy sixes and one for a Buick eight. Easy to make and they work fine. I have some Honda TBs that are 1.615. The Suzuki was 1.875
  18. kma4444
    kma4444
    That's some nice work there Rich, nice indeed
  19. Unkl Ian
    Unkl Ian
    Kinsler makes individual throttle bodies in various sizes.
    Hilborn is still in business, they might be able to help.
  20. i just had my stack injectors rebuilt by hilborn they were fast and the price was reasonable i've also used kinsler both worked as they said no problems . you should give them a call and alkydigger was very helpful
  21. RichFox
    RichFox
    I have some Ford Tarus 3 liter TBs. They have 1.940 bore. Sealed ball bearing throttle shafts and cost about $9 when I bought them. These things work good.
