ID this gauge pod/panel
Discussion in 'The Hokey Ass Message Board' started by Muttley, Feb 17, 2007.
  1. Muttley
    Muttley
    Does anyone know if this is an aftermarket part or did this come stock on something. I'd like to get one but I need to know what to look for first. I'm not looking for the gauges, just the panel.
  2. k-member
    k-member
    I don't know, but would be cool in a flathead powered something or other with water temp gauges for left and right side with oil pressure in the center. Cool piece.
  3. tommy
    tommy
    I've seen a few clusters like that. Most had a McCulloch super charger gauge. A combination gauge that would read vacuum at idle and then pressure as the blower spun up. I wouldn't be surprised if it turned out to be a McCulloch accessory with different gauges installed.(why would you need 2 vacuum gauges?) The ones with the McCulloch gauges are very pricey. I've only seen a few.
  4. theHIGHLANDER
    theHIGHLANDER
    Now that's kool. Fuck it muttley...build one. It doesn't look too hard to do. Although I understand the desire for a real one as well.
  5. Muttley
    Muttley
    HAHAHA.........you wouldnt want to see it anywhere near your car if I built it. I got the pics from Ebay a while back, the ad said nothing about where it came from except the owner thought it might have come out of a T-Bird. This or something similar would be perfect for my Coupe. The way the dash is there isnt much flat space to hang a panel from.
  6. Carter
    Carter
    Can't say for sure, but think it may be Studebaker
  7. KIRK!
    KIRK!
    I must have seen the same ad that said T-bird, because that was going to my answer too. Damn cool whatever it is.
  8. VintageIgnition
    VintageIgnition
    Alliance Vendor
    from ma
    I believe that is an aftermarket piece.
  9. Bruce Lancaster
    Bruce Lancaster
    I believe the connection with McCulloch blowers is correct.
