ID This Oil Pan
Discussion in 'The Hokey Ass Message Board' started by thishero, Feb 2, 2014.
  1. thishero
    thishero
    Name this oil pan... I got this oil pan about six months ago for my 302 Ford that is going into my 57 Ford F-100. It's rear sump because I'm running a camaro clip up front. However the Oil pickup he supplied with me is the wrong one. The tube runs into the dip-stick mount. It needs to angle back in instead of running straight, but I'm having trouble finding the correct one because I don't know what this came off of. The Dip stick mount sticks out about 1.5 inches. The large sump is approx. 9" and the smaller sump is 6"... Thanks in advance!
  2. 40FordGuy
    40FordGuy
    Can you use the timing chain cover, whith the dipstick tube in it ? Some small block Fords came with that set up.
    Sorry, I don't know the specific applications.
    4TTRUK
  3. Mark T
    Mark T
    You can't use a front mounted dipstick in a rear sump oil pan.
    I think your pan is from a Van, I'm thinking early 80's from the looks of it.
  4. Mike Miller
    Mike Miller
    Check the rear gasket surface, the round part, if it's too big you have a 351 Windsor truck pan.
  5. hemiwheelstand
    hemiwheelstand
    Hello, that oil pan is for an early Ford Bronco 66-77 with a small block ,the odd shape is for front rearend housing clearance.
    Chris
  6. Lol you ford guys are great!
    That just sounds funny - front rearend housing.
  7. thishero
    thishero
    I've been looking at a lot of pictures online from the suggestions I've been getting and it looks like it is from the early Bronco's. I'll go to the auto part store tomorrow and compare the pick-up, hopefully that's the one.
  8. thishero
    thishero
    WINNER! It's off of a '66-'77 Bronco, thanks Chris!
