Id this spindle
Discussion in 'The Hokey Ass Message Board' started by 5051, Dec 6, 2009.
  1. 5051
    5051
    Can someone ID this spindle for me. Don't know what year it is to match up for brakes.
  2. hotcoupe
    hotcoupe
    it appears to be `32-`34 ford. if the backing plate bolts are 3/8", i`m sure it is `32-`34. i have the pieces that you need to adapt hydraulic brakes-reasonable.
    spoke too soon, didn`t notice the two tie rod holes!
  3. Carter
    Carter
    I don't think it's 32-34.
    Thats a p***enger side spindle for a cross steer. Has two tie rod holes on arm and arm pointing to rear.
    could be 42-48 square back.
    Dave
  4. thunderbirdesq
    thunderbirdesq
    Definitely post 35... My first thought was 35-36, but once I blew up the pic, it almost looks like a round back that has been cut down on the sides??:confused: Is the casting # intact? What diameter are the backing plate bolt holes?
  5. dbradley
    dbradley
    Post the backing plate mounting dimensions (center to center on the mounting bolts) and do you have bearings or seals for the spindle? Their numbers may tip off what they are.
  6. mratt
    mratt
    Measure how long the king pin is. That will tell you the year-group.
    Thunderbirdesq said it may be a cut-modified. The king pin mearure
    will tell you.
  7. Carter
    Carter
    Just ran out in garage and looked at a few.
    Almost certain it is a 35-6.
    Dave
