Technical ID tri 5 rear end
Discussion in 'The Hokey Ass Message Board' started by Medic4lifejr, Apr 6, 2021.
  1. Medic4lifejr
    Medic4lifejr
    Hi
    Checking how do you id Tri 5 rear end?
    Gm stamped number 3725899 on the diff.
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    57-64 non posi unit.
    31hotrodguy likes this.
  3. Medic4lifejr
    Medic4lifejr
    So this rear end won’t be easy swap into 53? Just drilling spring perches
  4. 325w
    325w
    Well if you use the axle housing for the 5-7 drill the pads and use you pumpkin it’s all good.
  5. Medic4lifejr
    Medic4lifejr
    Well the guy selling the diff claims it’s a tri5 rear end. But gm number comes back as 57-64
  6. alchemy
    alchemy
    You said tri 5. I thought 1957 was a tri 5. He didn’t lie.
  7. Matt55folife
    Matt55folife
    squirrel likes this.
  8. squirrel
    A picture would indeed help....the center is removable, and could be installed in a 55-56 housing, but we can't see the housing.
    31hotrodguy and jimmy six like this.
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    58-64 housings are for coil springs with upper and lower control arms while 55-57 are for leaf springs. they are easily identified ..... a pic sure would help us, but if it has leaf spring pads it is a safe bet it is 55-57. and the canter section (pumpkin) could certainly have been changed over the last 65 or so years
    31hotrodguy and squirrel like this.
  10. 56sedandelivery
    56sedandelivery
    ^^^As stated, Tri-Five rear end housings will have spring pads^^^. The 57 housing is the ONLY one with a drain plug, otherwise it's a 55-56, and those are the same. Re-drill the spring locator pin holes 1-1/2 inches forward, and 1/2 inch inward (you could probably not drill them 1/2 inch inward); When we drilled ours the 1/2 inch inward, it looked like the springs were tilted in ever so slightly when looking at the car from the rear, but it was't a problem.
    I am Butch/56sedandelivery.
    31hotrodguy and irishsteve like this.
  11. Medic4lifejr
    Medic4lifejr
    Here’s the photo. The rear pumpkin cover has raised grove going down the the side rotation of the ring
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Based on the only numbers provided (which was only the 3rd member portion) that's best best I could answer at the time. Now that I see more info and a photo do as other have mentioned when placing a "Tri 5 Rear End" under your 53.
  13. Fordors
    Fordors
    The ‘55 and maybe ‘56 too (?) rear end housing used smaller diameter axle bearings, those could be a bit more difficult to locate if you needed them.
    Sorry, but I don’t have a definitive way to ID a ‘55-‘56 housing.
    jimmy six likes this.
  14. Johnny Gee
    Johnny Gee
    from Downey, Ca
    No drain plug.
    31hotrodguy and Moriarity like this.
  15. Moriarity
    Moriarity
    SUPER MODERATOR
    yes that is a 55-57 chev rear end, that is the one you want for your car. it is a bolt in swap once you offset drill the spring pads for the ctr bolt as mentioned above
  16. 56sedandelivery
    56sedandelivery
    Is there a drain plug in the housing (NOT the third member/the cast iron center section)? 55-56 third members have slightly thinner cast iron construction, and the axle bearings are smaller, as already noted. The "new" bearings out there are all made off-shore, and are poor quality (imagine that!); if you can find NOS bearings, that's the way to go.
