Idea for Cowl Steering, Will it work?
Discussion in 'The Hokey Ass Message Board' started by stan55, Jul 16, 2005.
  1. Clark
    Clark
    After giving it some thought I think the corvair box should work. The aluminum housing should be plenty strong.
    Most of the force isn't really at the box on a cowl steering car, it would be on the extended shaft and the bearing block at the cowl. I know this area takes the most abuse from abusing the cars I've built. I've tried a few different things and the problems are is always at the bearing block.
    How big is the pitman arm shaft that comes out of the box?
    Clark
  2. brandon
    brandon
    i used one thru the cowl on my tub .....used 2 u joints to get the wheel where it was needed......had the box mounted half way up the cowl......used a column heim joint to hang it off the dash .....(that part will probably get changed ......)
    seemed to steer alright ....and the car has a hemi in it ...so it can't be too bad....haha brandon
      16.7 KB
  3. joeycarpunk
    joeycarpunk
    from MN,USA
    I'd be interested in seeing that, if you could attach it to this post I'd be more likely to see it.
  4. dodgerodder
    dodgerodder
    One other box to consider is a 67-76 bmw 2002 series box. I enclosed a pic of a rebuilt one to show you. Its wide enough that you shouldn't have to extend the arm or get into that set of obstacles. It turns the right way to work for cowl steering, its 5 turns lock-to-lock, its manual(not power) and are pretty readily available used. Rebuilt they run over $200, but I bought a mint one I'll be using on my sedan off of eGay for $50. I'm not yet to that stage of the project, but heres a link to another hamber that used one.
    http://www.jalopyjournal.com/forum/showthread.php?t=22098&highlight=cowl+steering
    As with any cowl steering set-up, the obvious big thing to do is make the mounting strong, not just mounted to the cowl. Thats the biggest mistake I've seen done on cowl set-ups
  5. willowbilly3
    willowbilly3
    from Sturgis
    Just walk around any big rod gathering and you see some scary stuff on otherwise well built rods. It's good that you are researching your ideas. I think the chain could work, if it was heavy enough, like at least #50-60, and you had some sort of tightener to eliminate ALL the slack.
    But read the tech, good stuff and extending the pitman shaft is really the best way.
  6. denis4x4
    denis4x4
    from Colorado
    Here's the Schroeder unit. Note the brackets. Since this was a banger, mounting was simple. The drag link is paralell to the frame. It took several tries to get the pitman arm right.
  7. flatheadpete
    flatheadpete
    from Burton, MI
    I never thought I would hear or see Frank say or type 'yo baby'.
    I use a Model A box on my Bucket. No it's not cowl steering but the box is plenty strong.
  8. Jerry Day
    Jerry Day
    You can buy a new steering from Schroeder Steering in Burbank Ca That will FIT your project and work just fine, Jerry
  9. Scott
    Scott
    Kirk has one for sale right now
  10. 60s Mopar, under $100 on Ebay, no need to reverse.
