I need some help from you pro's i want to make a rollpan ,i know its gonna be louvered but how should it be ,tall ,small thx one of the front
Some nice body work coming together on that one. Not my place to comment on other peoples rides but since you have a *****foot suspension at the front I don't think I'd cover up that Jag rear end, have you considered bobbing the rear fenders 4-5 inches to fill the gap?
Just admiring your sedan,looks awsome...i have a couple questions for you.I have a 30 two door sedan, however i liked how you smoothe out the back rear of your sedan....did you grind the ribs down and fill w lead/mig or did you remove them and then weld/lead? I was also wondering about the headlight bar that is on your sedan???aftermarket/Kustom made??how much and if purchased where could i buy one??thanks for you time tyler
I'm with 30tudor on this one, 4/5 inch bob on the fenders and then I'd build a 3 or 4 inch high pan that curves up to about an inch or inch and a half at the center to show off the QC cover. Louver the deep part and call it good. And oh yeah, that front end is NOT a *****foot front end.
i marked the fender as in picture two where the fender lip should be but if the fenders are bobed would't look the rollpan to bulky or perhaps a cutout in the center contouring the rear cover as oldschool 66 says btw whats *****foot
Yes the ribs were cut of then tig welded and leaded, the headlightbar is homemade stainlessbar bended welded the headlight socket in between i hamered a round peace stainless halve round welded a nut on it and a tube at the round one cut the tube cutting relieves and weld them up comparing to original i also lowered the mounts on the fenderstruts hope this helps Art
