Technical Ideas for cool looking by-pass oil filtering on a '41 flathead
Discussion in 'Traditional Hot Rods' started by banjorear, Oct 2, 2018.
  1. banjorear
    banjorear
    So, you learn something every day. After speaking to Ronnie Roadster, I learned that a '41-42 Merc block can't easily be converted to full-flow oil filtering due to the lack of the send/return boss like a 59AB-series motor.
    This leaves me with two options: No filter or the by-p*** filter. I'd like to use a filter. I'm not looking for a better way to mount a by-p*** set than the stock style on the head.
    What have you guys done to solve this problem?
    Thanks,
    Tim
  2. tubman
    tubman
    The "traditional" answer is to use a "Beehive" filter housing mounted on the firewall. Speedway still sells a version; it doesn't quite look like what I remember, though.
    Hemiman 426 likes this.
  3. banjorear
    banjorear
    Thanks. I should have been more clear. Trying to stay with an early '40's time period. From what I gather, that Filcolator "beehive" came out in the '50's.
  4. tubman
    tubman
    In that case, "traditional" would be no filter.
  5. banjorear
    banjorear
    I know. I keep going back and forth on this.
  6. tubman
    tubman
    I'm not really up on Beehive filters, so I don't know when they first were used. Maybe someone else on here with more of a "historical" leaning will know; an original might be period correct. I personally like byp*** filters and think if maintained properly do a lot to keep the oil cleaner than a full flow system. I think they are much better suited for cars like ours and the way the are used than any full flow system.
  7. BJR
    BJR
    You would be better off with a filter regardless of the era.
  8. Atwater Mike
    Atwater Mike
    Filters are demonstrative of the reason that folks have livers...
  9. I know some cars used byp*** filters back in the '40's so just find a stock unit and plumb it up. I guess that won't have the custom look but that is what they would have done back in the 40's if someone wanted a filter.
  10. Scruffy49
    Scruffy49
    Had byp*** filters on the 218 and 230 Plymouth engines. Sold one, the other has gone missing. They worked fine. Preferred the one with copper hard lines to the one with rubber lines.
    4wd drive guys routinely add single to triple remote mount filters to their trucks. Indian Larry ran byp*** oil filters on his HD builds.
    You could get the best of both worlds... a small chrome version with hardlines. They are really for antique Harleys, and chrome leaves me cold but... beats no filter.
  11. Bursonaw
    Bursonaw
    I did a bit of research on this last year before adding a filter to my 8BA block.
    In general, a byp*** system filters approximately 20% of the oil that is pumped from your oil pump. At highway speeds a 100% of the oil in your engine gets filtered about every 20 minutes. Diesel trucks and some racing applications use a byp*** system because of the filtering capability. In those systems, the filter itself is different than a full flow filter and can filter down to about 5 microns. This can increase oil change times and reduce engine wear caused by contaminates.
    In a full flow oil system typically oil is filtered only down to about 20 microns.
    Looking at a period correct flathead application your options are limited. An original flathead byp*** filter was around 25 to 30 microns. If you go with a modern style byp*** filter you can get the advantages of better filtering but the drawback is a modern look. O’Brian Truckers offers a modified copy of an Hildebrant oil filter that takes a standard spin on oil filter that i was able to find at 20 microns. www.obrientruckers.com
    Personally took the tact that oil filtering at any level was better than none.
    Here is a picture of my install with the Hildebrant oil filter.
    If you decide to go with a byp*** filter you will also need a
    .060 oil feed restrictor. This is required to keep your engine oil pressure from dropping to low.
    This is the the one I used.
    I hope this helps you in your decision.
    Good luck.
    Sent from my iPad using Tapatalk
  12. classiccarjack
    classiccarjack
    Your engine looks... AWESOME
    Sent from my Moto Z (2) using The H.A.M.B. mobile app
  13. banjorear
    banjorear
  14. 40FORDPU
    40FORDPU
    I had a chrome chev filter in my stash that I used on my '40[​IMG]
    lothiandon1940 and Asphalt Demon like this.
  15. banjorear
    banjorear
    I'm leaning towards firewall mounting as well. It's a '28 Roadster, so things are a tad tight in there.
  16. FRANTZ makes chrome byp*** (Toilet Paper Filters) I use them and am convinced that they do what the manufacturer claims.
    tubman likes this.
  17. Petejoe
    Petejoe
    from Zoar, Ohio
    Not saying a byp*** filter isn’t effective here but I just change my oil every 1000 miles without a filtering system.
    We aren’t talking everyday drivers here.
    Bandit Billy likes this.
  18. Bandit Billy
    Bandit Billy
    If it takes an hour at freeway speed to cycle once through the filter 100%, the typical run to the cruise in or a putter about town will filter...almost nothing. I spent a ton of money on my flathead, closely followed the advice of H and H flatheads and many others that said "just like camel straights, no filter".
    classiccarjack likes this.
  19. Bursonaw
    Bursonaw
    Interesting article from Hot Rod Magazine on flatheads byp*** vs full flow oil filtering. They state that 10% of the oil goes through the filter and every 5 minutes at 2000 rpm 100% of the oil gets filtered in the engine.
    https://www.hotrod.com/articles/1210sr-oil-filters-for-flatheads/
    There is some pretty compelling demonstrations on U-tube about byp*** oil filter systems as well. Those systems are using 1 to 5 micron oil filters. Unfortunately finding a low micron oil filter that would fit in the Hildebrant cover is an issue. This brings in the million dollar question. Do you want a period correct look or a more effective oil filter system that looks modern? Or no filtering at all?
    Just a few more things to ponder over.
  20. banjorear
    banjorear
    Thank you. Yes, that is the question. Hershey is coming up, so I'm on the hunt for a period looking filter set-up that I can hang on the fire wall. I'm fairly certain it will be a by-p*** system of some sort. With the money it is going to cost to build this engine, I'd feel better with some type of filtering.
    Bursonaw likes this.
  21. Bigmac48
    Bigmac48
    from Dundalk Md
    image.jpeg image.jpeg image.jpeg TThought about putting one on my flatty was wondering anyone have a diagram or details were the supply and return hard lines go and what fittings and lines I will need to install ? 59ab thank you
    lothiandon1940 likes this.
  22. Bursonaw
    Bursonaw
    Here are some pictures that might help.
    Max Gearhead and Flathead Dave like this.
  23. sloppy jalopies
    sloppy jalopies
    25 years ago I carefully cut [2] stock filter housings, set them up with a modern filter inside... used steel lines as they are much smaller... tried to hide the screws that bolted the top down... used a smaller filter... worked well.
    Walt D. told me to plug a stock vent or return somewhere ? [memory]...
  24. Bigmac48
    Bigmac48
    from Dundalk Md
    Thank you ,that will definetly help
  25. Flathead Dave
    Flathead Dave
    from So. Cal.
    How so?
  26. tubman
    tubman
    In the forties, very few cars had oil filters as standard equipment. I can't see an aspiring hot rodder back in those days wasting his time chasing down a scarce item he thought he didn't need. I know in the fifties and sixties it would have been the last thing that I would have worried about.
    Flathead Dave likes this.
  27. Flathead Dave
    Flathead Dave
    from So. Cal.
    I did not know this. Informative. Thanks.
  28. tubman
    tubman
    It looks like bein' old is good for something.:)
    Max Gearhead likes this.
  29. Flathead Dave
    Flathead Dave
    from So. Cal.
    A person is never old. Only wiser...
  30. quickchangeV8
    quickchangeV8
    I have one of the Hildebrand remote oil filters that was made by O'Brien Tuckers, mounted on the firewall of my 59A flathead powered 1929 coupe. From what I can see so far, it seems to work just fine. The filter is mounted on the p***enger side of the firewall and I have 2 hoses coming from the filter to the br*** fittings on the drivers side of the engine block. I see no markings of any kind on the filter housing as to which one is the oil inlet and which one is the return line nor were there any instructions in the oil filter box showing you how to run the oil lines. Is there a right way to plumb in these oil lines to the Hildebrand filter housing or dosen't it really matter as to which one is the inlet and which one is the return line?
