Ideas on removing parts from a ravine
Discussion in 'The Hokey Ass Message Board' started by fatty, Mar 29, 2007.
  1. Too late they are already out. I came across 20 baby bull snakes already.
    I picked up one of those cheapy 12 volt winches and I will get some pics tommorrow. Its not going to be easy thats for sure. I could go one way and get in a four wheeler but there is too much debris concrete, wood, and metal. So I am going thru the other side and the owner said no to taking a chunk of fence out even temporary. :(
    If I am lucky i will get all of it and there is around 50 hhunks of metal that used to be 30's thru 60's cars and trucks.
  2. Section 8
    Section 8
    from AZ
    I have nothing to contribute, I just love the ***le of this thread.
  3. Sawracer
    Sawracer
    from socal
    Use sheaves or pulleys to gain mechanical advantage. 100 lbs double rigged (two pulleys) only takes 55 lbs to lift. If you use 4 pulleys, only 35 lbs pull will be necessary to lift 100 lbs. etc. Pm me if you need detailed instructions. Sheaves are found in every barn in Iowa worth its salt. I'm a lineman it's my business moving heavy stuff the smart way. Chopped50ford and I pulled an engine out of a truck using only two pulleys a rope, and manpower. The egyptians did it, so can you.[​IMG]
  4. deuces94
    deuces94
    from Minnesota
    Tie about a thousand balloons to them, put a dam down stream of the cabs, get as long a garden hose as necessary, fill the ravine with water, buy a pontoon boat and build a hoist onto it. When the balloons float the cabs to the top of the water................ Well I think you know where I'm going with this. And keep in mind you'll need some kind of dock to tie up to once you get to shore. Oh wait, I've got another idea that involves several pieces of 12" pipe and about 200 lbs. of black powder. Have you got access to some old bed mattresses?
  5. Bruce Lancaster
    Bruce Lancaster
    Invite a bunch of your friends; have a case or two of beer ready down there. Have another hidden up top. Spend some quality time drinking and discussing the problem at the bottom. When beer is almost gone, mention that there's more up top for when the job is done...and you're going up to get that case open for them.
  6. dirtbag13
    dirtbag13
    i see this thread is 2 yrs old but seeing as your from iowa i'm curious as to whether you got em out or not ! i'll come give ya a hand if not !:D:D
  7. HotRod33
    HotRod33
    Let me know where they are at and I will go get them for you... Then I will let you know when you can pick them up from my house......
  8. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Get your *** down there and carry it out. Ok all kidding aside. You will probably have to get down there and rig something up .4x4 lumber build something light but sturdy as hell .Id build a crate around body buy heavy rope or cable and winch the thing out. Without pictures. I dont know how much of a drop your talking about
  9. RichG
    RichG
    Use this, make short pulls and tie it off as you go...did you get down there or not, inquiring minds want to know:D
  10. Bruce Lancaster
    Bruce Lancaster
    Great. No response. Now we have to drag out not just the parts but a skeleton...
  11. rusty1
    rusty1
    ...we need pics!
  12. R A Wrench
    R A Wrench
    from Denver, Co
    I have been on a couple off road parts hunts. I recommend the use of winches, come-alongs, skids, large friends with strong backs and don't forget the beer. At times a gas powered chop saw came into use. Now, show us the pics. Thanks.
  13. RichG
    RichG
    Is that a traditional skeleton yet, or should we wait longer?:D
  14. Von Rigg Fink
    Von Rigg Fink
    from Garage
    hahahha friggen Great!
    lets wait until we get the cab out first:eek::D
  15. Bruce Lancaster
    Bruce Lancaster
    "Ran when parked...original owner included..."
  16. Von Rigg Fink
    Von Rigg Fink
    from Garage
    yer killin me man...oh **** i might be next:eek:
  17. mrpowderkeg
    mrpowderkeg
    I really want to see the ravine we're talking about. Take some friends, get some rope, and make a skyline across using trucks as anchors and hoist away? Worked for me recovering a mexican block 302.
    Matt
  18. Pins&Needles
    Pins&Needles
    from Santa Cruz
    I had no idea that Mcguiver was on the board! Holy ****! Dude you still rocking the mullet? I almost killed a lady with a bucket full of ice, on a rope, from a 30 story hotel building when I was 7 because of you! Good times!!!
  19. racer67x
    racer67x
    I have a Ramsey 8000 pound single line stall winch on my trailer..few years back some ***holes got a blazer stuck over a hill out in back of my farm.
    took the winch off and made a piece of plate to bolt it to that slid in the receiver of my truck.
    chained the truck off to a tree and used the winch to pull them out.
    it made the winch mobile and since has been used without the truck for stuff like you are doing,just chain the winch thru the plate to a tree and pull the stuff up the hill.
    you can carry the winch w/95 feet of cable in one hand and the battery in the other,get to your destination..chain to a tree and go for it.
  20. deuces94
    deuces94
    from Minnesota
    I don't think you had to say anything about my mullet!!!!! I think your pissed because the dam and balloon idea wasn't yours. At any rate are the cabs out of the ravine? Did my idea work?
  21. 61TBird
    61TBird
